SG 2100 motor
tibaboo
24
LNB.... Invacom
Captive works 800 pVR
31 " dish
SG 2100 motor
When ever i put it on usuals, it goes to the sat but i have to move it to the left or to the right , save it so i could get signal. HELP??????????????:mad:
Sounds like you need to tweak your alignment.
Using USALS go to your True South Sat, do you get a lock without having to move it?
yes. It locks on the sat, but no signal.. I have to tweak it with the remote
i'm in miami and the setup for the motor is 25/64 and i also set my dish at 30 . I even use a meter to get better signal. But once i change to anothere sat (no signal) and go back tp previous sat (No signal ) also
When I said "Lock" I mean, Are you getting Quality?
According to this Calc Page...
Satellite Look Angles Satellite Heading Calculator Azimuth Elevation Skew Tilt LNBF Latitude and Longitude values
Your Dish should be set to 26 (+ / - a few)
Motor is set to Your Latitude: 25.8 (exact as possible)
AMC 5 @ 79 west is your True South, are you getting Quality there using USALS only?
AMC 5 TP info: 11900 H 2170
If so, then you go to a different Sat using USALS like Horz 2 @ 74 west you Do Not get Quality, then return to AMC5 using USALS you do not get Quality.
Check motor "slop", gently push and pull the Dish, is there any play?
Your LocationSatellite DataDish Setup DataLatitude: 25.7136°
Longitude: -80.4504°
Name: 97.0W Galaxy 25
Distance: 36800km
Motor Latitude: 25.7°
Declination Angle: 4.3°
Dish Elevation: °
Elevation: 54.7°
Azimuth (true): 214.4°
Azimuth (mag.): 220.0° using Compass
LNB Skew: 30.6°
Dish Skew: 90.0°
this is what i got from the link you gave me
So i need to set up the motor on the 25.7 on 1 side and 54.7 on the other side and my dish at 30. AM I RIGHT
The play in the motor's arm needs to be taken care of...
http://www.satelliteguys.us/free-air-fta-discussion/103698-sg-2100-loose-motor-shaft.html
Here is what I got, you do not need to add the declination angle.
Latitude: 25.7136°
Distance: 36527km
Dish Elevation: 26°
Elevation: 59.9°
Azimuth (true): 180.0°
Azimuth (mag.): 185.6° using Compass
LNB Skew: 0.0°
Dish Skew: 90.0°
Thanks a lot, i will try to fix the arm and i will let you know.....Thanks for your feedback
Confused about fta channels...?!
Problem getting 22 kHz tone switch & 2 DiSEqC's to work together
