Signal strength and quality question
pollux
34
los angeles
On some FTA channels, you could have 90% signal strength and 0-10% signal quality, yet the video can be viewed flawlessly. for example, signal quality of the Ion-HD channels on AMC1 are low, but the HD can still be viewed. On the other hand, the DW channel has 90% signal strength, but when the signal quality drops below 65%, it starts to lose the image. Apparently there are other factors involved, what are they? TIA
Mostly, channels being broadcast rely upon the "lobe" or bandwidth they have payed for; paying for what they really get. If they are looking for 999's there is perfect compared to others; environmental factors of any long term requirement usually hold keys to better equipment and "productions". Here, signal strengths and qualitys of each product purchased really make the cost factors soar; as does "the intended audience (language, continents, areas) shown. A basic way to say is every bit matters; and performance in all that matters is the broadcast specs; then spot on map and dish size dish install cable used receiver used meet in a final received "production"! Signal strength means lnbf dish combo in the direction it is aimed; plus cable loss (length). Quality means the numbers the receivers micro uses all at the same 60 hz needed makes a picture receivable at the end of the cable it is hooked to. If the margins in the micro mems receiver says good; it will show on the tv. Scan ok? Good! Every receiver show differences in strength and quality "numbers"; scanning what it can anyway it can; but only when the dish is correctly tuned to the satellite it wants; or has been programmed to scan. Each transponder it picks up is different in received power (strength) and an exact science in numeration (quality) also; which both depend on each being exactly perfect for each you want!
Yes, they are each, as a number used in the whole of things; the more errors; the more it must "correct" a very basic part of its "enumeration" which is problematic when something called noise makes errors; in the solution to the reception it makes a decision every 60th of a second: and is part of the decision a recvr finalizes every sixtyth of a second. Remember, if the dish is 20 percent off track; it adds 20 percent more noise to the signal as strength.
Basically, forward error correction (FEC) is the reason some transponders are lockable at low quality, while others require very high quality to lock. A 1/2 FEC will lock very low. A 5/6 needs decent quality to lock. A 7/8 needs very good quality and usually a large dish.
thanks, that make sense,
on AMC1 the ion-hd @ 4040H fec is 2/3; while DW @3740V fec is 7/8
satpro manhattan rs1933
