Single, Dual, Twin, Quad...HELP!!
tankerman
SatelliteGuys Guru
147
Northeastern Maryland
OK, I think I've purchased all of the correct products this time. Some one correct me if I'm wrong.
I'm going to use a DP34 switch.
I'm going to use a Dish 500 with a Dish pro TWIN lnb, for 119 and 110. I'm going to connect the 2 outputs of the twin into 2 of the inputs on the switch.
This is the part, I'm not sure of...
I'm going to use a Dish 300 (with a D shaped arm) with a Dish pro DUAL lnb, for 61.5. I'm going to connect 1 of the outputs of the dual onto 1 of the inputs on the switch. I'm going to leave the other side of the dual empty.
Please tell me this is right.
I've used legecy for about 7 years, and I can hook that up with no problem.
The Dish pro is all new to me.
correct
a dual is used for one satellite (61.5)
a twin is for 2 satellites (110 & 119)..looks like 2 duals taped together
a quad is like a twin but has 4 outputs
tankerman:
That's exactly the setup I'm running right now. I see no problems with it.
NightRyder
