SiriusXM streaming bandwidth
TheKrell
A mighty and noble race originating on Altair IV.
39,058
47,069
Fairfax, VA
Does anybody know how much bandwidth is used when we stream a SiriusXM channel? The reason I ask is I usually play Spa Instrumental on an Echo at work by turning on my cell phone's hot spot. There was no LTE either here in Silver Spring nor at home in Fairfax! Edge was hopelessly inadequate. No, my phone does not support 5G so I don't know if that was still working.
I cant directly answer your question but the phone app gives you a choice of three quality settings. I'm guessing the echo uses the "Normal" setting???
Maximum = 320kbps or ~ 140MB/hr
High = 160kbps or ~ 70MB/hr
Normal = 128kbps or ~ 56MB/hr
Reactions: TheKrell and Foxbat
Here's what I see using my Denon Home 150 HEOS streaming speakers:
I don't have the Amazon Echo speakers but between TRG's answer and this you should have a good idea of your potential date usage. Also, Spa Instrumental isn't one of the SiriusXM channels I can stream through HEOS for whatever reason. I can use AirPlay to play music from the SiriusXM an my iPhone or iPad to listen to that channel.
Reactions: TheKrell and TRG
Free XM/Sirius
Starmate Color Change
