Size of slimline base?(part that can be screwed to house)
Chances are high that a slimline footing will not fit there properly, the basic mast barely fits. It might work on the flooring part but then you will have LOS issues as it shoots over the house. Is a roof or pole mount feasible?
Make sure they clean up those lines, that install is horrible. And make sure they don't run the new Lines through your ventilation, and actually bond the grounding to the houses electrical system.
If you need it on the deck, you may try and get them to rig up a pole mount for the corner using customer supplied 2" ID U bolts would reccomend at least 4 of them.
thats not my install its some picture i found...i probably need to go with an under eave mount under the deck do the installers carry these or do i need to purchase one? my deck is on the proper side of the house so i will not have LOS issues.
Directv should send AT&t a thank you card.
CIHD Censoring Content?
