ViP211z, 1000.4 dish, triple LNB, mobile "RV" setup
I use this setup in an RV and move frequently, probably setting up 26 times per year. The dish is on a PVC 4 legged stand and gets stowed in the belly of the beast between trips. Been doing this for over a decade, so it's a proven setup.
Last summer I discovered I could call DISH, tell them I'm in a new city and they would re-program my local channels. Sweet, even though I rarely watch local channels. When I had them switch it back <<<sometime around that time>>> I discovered certain channels wouldn't work. THIS MAY OR MAY NOT BE PART OF MY PROBLEM . . . . . actually, I doubt it is, and that it's just "coincidental".
So yesterday I started digging in. DISH was absolutely no help and 4 agents wasted 1.5 hours of my time, but what else is new? The problem is I can view ch 367 but not ch 369 and both are coming from the same 72 satellite. BTW, I don't watch MTV either but several movie channels are out also. Wierd, huh?
The house is on an identical setup. The same receiver works in the house being fed from a different 1000.4 triple LNB dish. The only difference is the coax and the LNB, and I eliminated the coax by connecting straight off the umbilical cord out of the RV's LNB. I even changed ports from 2 to 3 on the LNB, and did a Check Switch (LNB) procedure in Dish's Point Dish menu (Menu, 6-1-1). Signal strength for this test is 39. (In the past I've been able to watch all channels with signal strength in the mid 20's).
It seems odd an LNB would allow some channels to pass through but, from the same satellite, not others. I've exhausted the possibilities. Can a bad LNB do this?
Thanks for advice,
- bob
Thanks for advice,
- bob
