SuperDish Question
Frank Jr.
Beati pacifici 5:9
14,178
1,966
Columbia S.C.
The left outboard lnb on my superdish has two female type connectors on it. The extreme left connector is exposed with no connection, should it be weather sealed? Everyone have a great weekend and thanks in advance.
The DP-34 switch comes with plastic caps over all the connectors. Since three are used for 105/121, 110, 119 for the SuperDish feeds plus one per receiver you could use one of those caps that are no longer needed to put on the 119/110 lnbf that is on the outer edge that could be exposed to moisture.
Elmer's Glue works... short temp fix until you get something more permanent on it. It peels off rather easily too.
119 problems
Anyone else fill out the form at www.iwantmyhdtv.com?
