Technotrend TT-connect S2-3600
wlong1136
7
This box I bought is supposed to plug into my LBN coax and by selecting the the proper satellite, search and find all DVB transmissions. I've hiiked it p to both my BOD ku and my MPEG2 antenna and receive no signal. My ku on the 4DTV works when hooked back up as does the Pansat 2400A. Anyone out there in this never never land have one that works? If it does with a system like mine how did you get it to work? I have a 9' C/Ku and a MPEG2 ku separate system.
It's USB and everything on the CD seems to be in German and their support's reply had no bearing on my question. I've chose a good DVB Satellite, G5, Frequency is correct, polarity's correct and Symbol reat is correct still no picture. (No signal)
I have the Technotrend TT-connect S2-3600. It works fine with the BDA drivers.
Have you installed the BDA driver?
Are you using TT Media Center?
G5 (Galaxy 14) doesn't have much FTA on it. Just about everything is encrypted. You should be able to receive the TBN mux 3720 H 26667.
TT Media Center won't find all DVB and DVB-S2 signals on a satellite. It will only search for signals that are listed in it's satellite transponder ini files.
If you don't get any help somewhere else, i can translate it for you from german to english ( if it's not too much text :D).
Holy Smokes!
Can I use my FTA dish with a Dish PrePaid 301 Reciever?
