Terk TV44 with DPP44
sgip2000
99
Hillsboro, OR
Has anyone installed a Terk TV44 antenna with a DPP44 switch?
I am curious if power from the DPP44 power inserter would be an issue.
Thanks.
A DPP44 is satellite equipment, and a Terk antenna is for OTA. They are not compatible.
Thanks for the response.
I understand that they are two different devices; however, perhaps you didn't quite understand my question.
The TV44 has a diplexer built in but is designed to be wired to the LNBF and then has outputs that go into the house.
What I was asking is if anyone knows if using a DPP44 with inserter would generate too much voltage for the diplexer in the TV44 to handle.
I doubt it, because the DPP44 puts out 18V, and so does the power supply for an OTA preamp, provided the Terk is a amplified model.
My CM7777 preamp runs on 18V too.
sight to behold
Hd offers
