Now that we know we can terminate the unused port on an LNB, how about a switch, like the DPP44?
I got out the ol voltmeter again.
The 4 satellite inputs that connect to LNBs, Do not terminate these, cap them w/ plastic/rubber.
If you have 3 inputs, and 1 unused, the unused has no voltage until you run a check switch, as I have discovered Aprox 17V come on during a check switch. ( It's most likely supplying power looking for an LNB )
The 4 ports to connect another switch, I would also cap these instead of terminating them since they kind of, in a way, but not exactly are a passthrough to the inputs.
Now the 4 outputs to receivers. I saw no voltage on these, so possibly safe to terminate.
Now on to terminators... There is no real advantage to terminating LNBs as like there is with Cable TV, which with cable, reduces ghosting, by not allowing the signal to reverse back through the coax. and a nice tight plastic, or rubber cap will waterproof better, in my opinion.
