Timer padding and record plus
blockisle9
217
Ever since NBR version 232. When I set a timer lets say Law and Order on NBC Sunday at 9:00PM and Crossing Jordan on NBC Sunday at 9:30PM. Law and Order records to Tuner 2 and Crossing Jordan records to tuner 1.
I have record plus set to tuner 2.
Before NBR, record plus would ignore the 1 minuet before and the 3 minuet after padding and record both to tuner 2. Now with NBR it seems to not ignore it and send the second show to the other tuner (tuner1).
Is this a bug or am I doing something wrong?
When you create your timer, go to options and set the before and after to 0 / 0. This is an annoying, currently non-changeable default "feature" of the 522 that still defaults to 1 /3.
Ok, But, am I crazy or did it work with out changing the padding before NBR?
Mine has always recorded back to back shows doing the first show on 2 and the second on 1.
Thanks all!
But im sure it use to recard them both on the same tuner with out changing the padding.
blockisle9 said:
Thanks all!
Yes, it did use to ignore the padding automatically and record both shows on the same tuner. I think maybe you had to be in dual mode for it to work that way.
I find this mildly annoying also.
Yes, I recall that with Record-Plus set to tuner 2 in Dual-Mode it would drop the padding for back-to-back shows on the same channel and keep it all on tuner 2, but never in Single Mode. I used to switch to Dual-Mode, set the timers, then go back to Single Mode. That would keep them on the same tuner. I got lazy and don't do it anymore, so I'm not 100% sure it still works like that.
Probably an ancient question...
Q: Deleting Protected Program - Dish loaded
