I'm sorry, I can't just let this go. You're deliberately confusing the issue, in my opinion, to try and confuse others. Look, this is real simple. There were 2 rates: Pre-judgement infringement and post-judgement infringement. The first was set by the jury, $25. HJF did say he thought that rate was low, but he went with it anyway because nobody objected. The second rate was the post-judgement rate and it was initially set at $25 as well. HJF used the same jury rate for this, but failed to explain why he did so. This is what was remanded. He then did the analysis and came up with a number that was 4X the original jury rate for post-judgement infringment. Period. That's it. 4X was the number: not 3X, nor 2X, but 4X. The Monty Python fans will get that last sentence.
Unfortunately you only read selectively what I said. In Paice, Paice asked for $250, Toyota asked for $17, the judge initially said $25, Paice appealed because they wanted $250 not $25, the appeals court vacated the judge's rate. On remand, both again argued for their positions, and the judge ruled a $96.
So far so good? Now in this case, TiVo asked for $2.25, E* said $1.00, the judge said $1.25, yes it is abased on the original jury's rate.
If TiVo does not like it, TiVo can appeal, arguing that the $1.25 is too low, $2.25 should be applied, if TiVo wins, then the court can grant the $2.25, or some thig between $1.25 and $2.25. But TiVo first must object to the $1.25 rate, then win on appeal, and then have the rate raised, but not over the $2.25 TiVo asked for themselves. I hope such baby step talk finally works this time.
Judge Folsom will not set on a rate that is higher than asked for. Now on the damages, it can change, but will not be over 3 times more because the law does not give the court the power to go above that. Treble damage is the most a court can hand down.
			Wrong again, but thanks for playing. Again, think about pre-judgement infringement versus post-judgement infringement.
The $1.25 Judge Folsom just set is the post-judgment rate, only that it is the same as the pre- in this case. TiVo wanted $2.25 post- using your argument that post- can be higher than pre-, but the judge said in this case, no still the same.
			Your above comments are for the former, not the latter. The former is in the books and was decided yesterday. The latter is what is being discussed here,
Then we are discussing different things. But still you need to wait till TiVo ask the judge for the $5. They asked for $2.25 and got $1.25, that is a fact, but if you want to speculate that in the future it can be $5, be my guest, what I am saying is if you do at least wait for TiVo to ask for it.
			and any analysis of what rate would be fair at this time would be radically higher than the rate set yesterday. The rate that was set yesterday was based on an assumed negotiation that would have taken place in 2006. Clearly, the legal footing has changed significantly at this point and if you will read HJF's decision from yesterday you will see that he says as much in the ruling. I won't post a link, because I got in trouble for it last time, but most of you can find it, I think.
Again exactly what TiVo argued on 9/4/08, but the judge did not buy it. He said still the $1.25 as back in 06.
			Any private settlement negotiations will not be part of a court filing and there won't be any objections to the court about whatever rate TiVo asks for.
Yes it does, it in fact happens a lot. If the court says $1.25 is a reasonable rate, and TiVo in private insists $5, there is ground for appeal to the court.
			If HJF is forced to set a post-judgement rate, you can be assured it will be somewhere north of 3X the pre-judgement rate.
TiVo already tried to "force" him to hand them a $2.25 post-judgment rate but did not get it. So if later TiVo tries to "force" a $5, good luck. Go read Judge Folsom's reasoning why not $2.25.
			HJF has already said the software is not more than colorably different and the new devices run the same software.
Judge Folsom never said the latter part, the most you can say about the software in the VIPs is they are similar. To argue for infringement, the term used is not "similar" rather "substantially the same."
