Hello all.
I currently have 2 Dish 510s, one in the living room and one in the master bedroom. Both cable outlets are on interior walls. My 1-story house is on a slab, but does have good attic access. I have one of those central panels in the laundry room where all the cable wires come into the house. There are currently 2 lines coming from the satellite dish into the attic which are then routed into the central panel. Of course when the house was built, only one line was run from the panel to each cable outlet. I'm located near Charlotte, NC.
I want to upgrade to 2 Directv dual-tuner DVRs, so I placed an order a few days ago. I wasn't off to a good start when Directv said that according to their records, I wasn't a new customer. Turns out that because I used to have Directv DSL in 2003, my name and address were already in their system. Got that whole mess straightened out and then scheduled the installation for today.
So the installer came today and said it would be $100 extra (payable directly to him) to run the 3rd and 4th lines through the attic to the panel and then to the outlets. He said he'd have to install a wallfish for each room so we could use the second tuners. Then he looked at the panel and said he didn't even know if he'd be able to run the cable down to it from the attic because there isn't much space in it due to the way the other cables were run in the past.
So he tried for about 30 minutes to run cable from the attic and couldn't ever get it into the panel. He called his supervisor who said the only other option would be to drill through an exterior wall in the bedroom and run the cable around the outside of the house to the satellite. He would still have to install a wallfish for the living room because it's in the dead center of the house and nowhere near an exterior wall. I said no to that. He then called the company's lead tech but neither of them could come up with any other options. So I told him I'd stick with the setup I have now and he cancelled the order.
So my question is, am I stuck with my current Dish setup? My husband and I really want dual-tuner DVRs (even if they're R15s -- they gotta be better than Dish 510s!). We would appreciate any advice from you gurus!
Thanks,
Jenny
Thanks,
Jenny
