TV Antenna/ Cable In Port
  • WELCOME TO THE NEW SERVER!
viqventeur
47
San Diego
Has anyone had success using this port? Let's say you have a 522 for Sat programming, but kept your cable service as well. You have two sat feed lines, and a seperate cable for the cable service. You hook the cable line to the TV Antenna/ Cable In port on the rec. If you used RCA cables for your input to the TV. How do you switch between Sat and cable? How would this work if instead of the cable service, it was the mirrored signal from a 510? Thanks.
And Yes i have the regular cable hooked up to the right place.......... and it doesnt come through when powered down.
It only passes through using the tv out coax on tv 1. you can't output it on any other outputs or record it.
