Tweaking 61.5
bobvick
4,464
2,163
Northwest Alabama
Does anyone know off the top of their head what is the best transponder(s) to peak 61.5 on? I think that the wind has shifted my 30'' Winegard dish that I have parked on 61.5 and I was planning on tweaking it today with My SuperBuddy. I will appreciate any suggestions. Thanks
Try 11. I used to use that transponder to tweak it. I get 55 strength. ON 72.7 you use 19 or 21 transponders. I am using an eastern arc 1000.4 sat dish for 61.5/77/72.7 sats.
On you SB..Go to Menu use Dish 1000.4 Eastern Arc Setting or you can try using 61.5 "Dish 500 Pro" or "Dish 500 Legacy"..Limit Scan, Change Sat to 61.5, Peak Dish. Run limit scan.
Tp's listed on the scan are 14, 15, 16 and 25
I will make inquiries as to the acceptable signal strengths.
If I recall, here in the US Southeast, acceptable "pass" signal strengths on the SB Limit Scan for 61.5 are in the 60's and 70's
