Uplink Activity Report - 9/4/8 - 3 AM 94 changes
JohnH
Godfather of the Uplink Reports
3,013
Kansas City, Missouri
UPLINK ACTIVITY: SAMPLE TAKEN 09-04-2008 03:02:00 TO 09-04-2008 03:03:06 ET
11 ADD(S)
ADD 403 NHLN MPEG2 SD Tp 19 EchoStar 11 110w UNAVAIL HIDE
ADD 403 NHLN MPEG4 SD Tp 19 EchoStar 6 72.7w UNAVAIL HIDE
ADD 625 NHLN MPEG2 SD Tp 19 EchoStar 11 110w UNAVAIL HIDE
ADD 625 NHLN MPEG4 SD Tp 19 EchoStar 6 72.7w UNAVAIL HIDE
ADD 14830 KUAS1 EEPG Tp 5 Arizona EchoStar 7 119w UNAVAIL HIDE
ADD 15147 WWAY2 EEPG Tp 29 Spot 2 EchoStar 10 110w UNAVAIL HIDE
ADD 15149 WECT2 EEPG Tp 27 Spot 2 EchoStar 10 110w UNAVAIL HIDE
ADD 15150 WUNJ2 EEPG Tp 27 Spot 2 EchoStar 10 110w UNAVAIL HIDE
ADD 15151 WUNJ3 EEPG Tp 27 Spot 2 EchoStar 10 110w UNAVAIL HIDE
ADD 15152 WUNJ4 EEPG Tp 27 Spot 2 EchoStar 10 110w UNAVAIL HIDE
ADD 15153 WUNJ5 EEPG Tp 27 Spot 2 EchoStar 10 110w UNAVAIL HIDE
18 CHANGE(S)
CHNG 7550 KLKN MPEG2 SD Tp 2 EchoStar 11 110w AVAIL HIDE MAP 8
TO 7550 KLKN{LINCOLN, NE} MPEG2 SD Tp 2 EchoStar 11 110w AVAIL HIDE MAP2 8
CHNG 7551 KOLN MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP 10
TO 7551 KOLN{LINCOLN, NE} MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP2 10
CHNG 7552 KHAS MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP 5
TO 7552 KHAS{HASTINGS, NE} MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP2 5
CHNG 7553 KTVG MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP 17
TO 7553 KTVG{GRAND ISLAND, NE} MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP2 17
CHNG 7554 KCWL MPEG2 SD Tp 29 Spot 29 EchoStar 10 110w AVAIL HIDE MAP 51
TO 7554 KCWL{LINCOLN, NE} MPEG2 SD Tp 29 Spot 29 EchoStar 10 110w AVAIL HIDE MAP2 51
CHNG 7556 KUON MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP 12
TO 7556 KUON{LINCOLN, NE} MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP2 12
CHNG 7557 KHGI MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP 13
TO 7557 KHGI{KEARNEY, NE} MPEG2 SD Tp 27 Spot 29 EchoStar 10 110w AVAIL HIDE MAP2 13
CHNG 8920 KTUL MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 8
TO 8920 KTUL{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 8
CHNG 8921 KOTV MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 6
TO 8921 KOTV{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 6
CHNG 8922 KJRH MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 2
TO 8922 KJRH{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 2
CHNG 8923 KOKI MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 23
TO 8923 KOKI{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 23
CHNG 8924 KQCW MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 19
TO 8924 KQCW{MUSKOGEE, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 19
CHNG 8925 KMYT MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 41
TO 8925 KMYT{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 41
CHNG 8926 KOED MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 11
TO 8926 KOED{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 11
CHNG 8927 KGEB MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 53
TO 8927 KGEB{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 53
CHNG 8928 KWHB MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 47
TO 8928 KWHB{TULSA, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 47
CHNG 8929 KTPX MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 44
TO 8929 KTPX{OKMULGEE, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 44
CHNG 8930 KRSC MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP 35
TO 8930 KRSC{CLAREMORE, OK} MPEG2 SD Tp 4 Spot 20 EchoStar 10 110w AVAIL HIDE MAP2 35
38 DELETE(S)
DEL 14013 KVMD1 EEPG Tp 8 EchoStar 11 110w UNAVAIL HIDE
DEL 14015 KQED1 EEPG Tp 8 EchoStar 11 110w UNAVAIL HIDE
DEL 14022 KRCB1 EEPG Tp 8 EchoStar 11 110w UNAVAIL HIDE
DEL 14086 KYIN2 EEPG Tp 12 Spot 4 EchoStar 10 110w UNAVAIL HIDE
DEL 14089 WPHL2 EEPG Tp 12 Spot 4 EchoStar 10 110w UNAVAIL HIDE
DEL 14131 WMPT4 EEPG Tp 23 Spot 5 EchoStar 10 110w UNAVAIL HIDE
DEL 14132 WMPT5 EEPG Tp 23 Spot 5 EchoStar 10 110w UNAVAIL HIDE
DEL 14197 WNPB2 EEPG Tp 32 EchoStar 5 129w UNAVAIL HIDE
DEL 14297 KRCW2 EEPG Tp 27 Spot 44 EchoStar 10 110w UNAVAIL HIDE
DEL 14324 WPBY2 EEPG Tp 32 EchoStar 5 129w UNAVAIL HIDE
DEL 14375 WIS3 EEPG Tp 7 Carolinas EchoStar 7 119w UNAVAIL HIDE
DEL 14407 WFIE3 EEPG Tp 25 Spot 14 EchoStar 10 110w UNAVAIL HIDE
DEL 14421 WPBY4 EEPG Tp 32 EchoStar 5 129w UNAVAIL HIDE
DEL 14428 WNPB4 EEPG Tp 26 Spot 19 EchoStar 10 110w UNAVAIL HIDE
DEL 14439 WYZZ2 EEPG Tp 27 Spot 19 EchoStar 10 110w UNAVAIL HIDE
DEL 14483 KCBD3 EEPG Tp 31 EchoStar 1 148w UNAVAIL HIDE
DEL 14503 WTTE2 EEPG Tp 21 EchoStar 5 129w UNAVAIL HIDE
DEL 14535 KWGN2 EEPG Tp 20 EchoStar 7 119w UNAVAIL HIDE
DEL 14568 WRNN1 EEPG Tp 20 Spot 4 EchoStar 10 110w UNAVAIL HIDE
DEL 14625 WFXG2 EEPG Tp 26 Spot 6 EchoStar 10 110w UNAVAIL HIDE
DEL 14669 WACH2 EEPG Tp 7 Carolinas EchoStar 7 119w UNAVAIL HIDE
DEL 14748 KCTV3 EEPG Tp 18 Spot 24 EchoStar 10 110w UNAVAIL HIDE
DEL 14764 WDKY2 EEPG Tp 4 Spot 10 EchoStar 10 110w UNAVAIL HIDE
DEL 14934 KSWO2 EEPG Tp 16 EchoStar 5 129w UNAVAIL HIDE
DEL 14957 WUHF2 EEPG Tp 27 Spot 9 EchoStar 10 110w UNAVAIL HIDE
DEL 14970 KSNW2 EEPG Tp 27 Spot 29 EchoStar 10 110w UNAVAIL HIDE
DEL 14976 KASA2 EEPG Tp 27 Spot 31 EchoStar 10 110w UNAVAIL HIDE
DEL 14987 WLVI2 EEPG Tp 26 Spot 4 EchoStar 10 110w UNAVAIL HIDE
DEL 14992 WCHS2 EEPG Tp 32 EchoStar 5 129w UNAVAIL HIDE
DEL 15034 WMYV2 EEPG Tp 31 Spot 5 EchoStar 10 110w UNAVAIL HIDE
DEL 15092 KMYQ2 EEPG Tp 3 Northwest EchoStar 7 119w UNAVAIL HIDE
DEL 15108 KOLD3 EEPG Tp 7 Arizona EchoStar 7 119w UNAVAIL HIDE
DEL 15127 KHQA2 EEPG Tp 26 Spot 19 EchoStar 10 110w UNAVAIL HIDE
DEL 15135 KSIN2 EEPG Tp 5 EchoStar 5 129w UNAVAIL HIDE
DEL 15146 KDIN2 EEPG Tp 20 Spot 24 EchoStar 10 110w UNAVAIL HIDE
DEL 15155 KBIN2 EEPG Tp 20 Spot 24 EchoStar 10 110w UNAVAIL HIDE
DEL 15237 WSIU4 EEPG Tp 5 EchoStar 11 110w UNAVAIL HIDE
DEL 15254 WUSI4 EEPG Tp 5 Midwest EchoStar 7 119w UNAVAIL HIDE
21 MOVE(S) (May include other changes as well.)
MOVE 103 ONPPV MPEG2 SD Tp 19 EchoStar 11 110w AT200? PREV FTA
TO 103 ONPPV MPEG2 SD Tp 16 EchoStar 11 110w AT200? PREV FTA
MOVE 199 CHILR MPEG2 SD Tp 19 EchoStar 11 110w AT250?
TO 199 CHILR MPEG2 SD Tp 1 EchoStar 11 110w AT250?
MOVE 231 RFDTV MPEG2 SD Tp 19 EchoStar 11 110w AT200?
TO 231 RFDTV MPEG2 SD Tp 21 EchoStar 11 110w AT200?
MOVE 264 KTV MPEG2 SD Tp 19 EchoStar 11 110w AT100?
TO 264 KTV MPEG2 SD Tp 2 EchoStar 11 110w AT100?
MOVE 343 EACTN MPEG2 SD Tp 19 EchoStar 11 110w AVAIL
TO 343 EACTN MPEG2 SD Tp 5 EchoStar 11 110w AVAIL
MOVE 345 EDRAM MPEG2 SD Tp 19 EchoStar 11 110w AT250?
TO 345 EDRAM MPEG2 SD Tp 6 EchoStar 11 110w AT250?
MOVE 346 ELOVE MPEG2 SD Tp 19 EchoStar 11 110w AVAIL
TO 346 ELOVE MPEG2 SD Tp 16 EchoStar 11 110w AVAIL
MOVE 468 ORDER MPEG2 HD Tp 19 EchoStar 11 110w AT200? PREV FTA
TO 468 ORDER MPEG2 HD Tp 10 EchoStar 11 110w AT200? PREV FTA
MOVE 498 PLBYE MPEG2 SD Tp 19 EchoStar 11 110w ADULT?
TO 498 PLBYE MPEG2 SD Tp 3 EchoStar 11 110w ADULT?
MOVE 500 ONPPV MPEG2 SD Tp 19 EchoStar 11 110w AT200? PREV FTA
TO 500 ONPPV MPEG2 SD Tp 16 EchoStar 11 110w AT200? PREV FTA
MOVE 840 TVEI MPEG2 SD Tp 19 EchoStar 11 110w AVAIL
TO 840 TVEI MPEG2 SD Tp 9 EchoStar 11 110w AVAIL
MOVE 865 CINEL MPEG2 SD Tp 19 EchoStar 11 110w AVAIL
TO 865 CINEL MPEG2 SD Tp 11 EchoStar 11 110w AVAIL
MOVE 872 TR3S MPEG2 SD Tp 19 EchoStar 11 110w AVAIL HIDE
TO 872 TR3S MPEG2 SD Tp 16 EchoStar 11 110w AVAIL HIDE
MOVE 895 CHILR MPEG2 SD Tp 19 EchoStar 11 110w AVAIL
TO 895 CHILR MPEG2 SD Tp 1 EchoStar 11 110w AVAIL
MOVE 5813 SKDL MPEG2 SD Tp 16 EchoStar 11 110w UNAVAIL HIDE
TO 5813 SKDL MPEG2 SD Tp 24 EchoStar 11 110w UNAVAIL HIDE
MOVE 6799 TURBO MPEG2 SD VIP Tp 19 EchoStar 11 110w AT100? PREV MAP2 75
TO 6799 TURBO MPEG2 SD VIP Tp 10 EchoStar 11 110w AT100? PREV MAP2 75
MOVE 9394 KTV MPEG2 SD Tp 19 EchoStar 11 110w AT100? HIDE
TO 9394 KTV MPEG2 SD Tp 2 EchoStar 11 110w AT100? HIDE
MOVE 9398 RFDTV MPEG2 SD Tp 19 EchoStar 11 110w AT100? HIDE
TO 9398 RFDTV MPEG2 SD Tp 21 EchoStar 11 110w AT100? HIDE
MOVE 9464 ORDER MPEG2 HD Tp 19 EchoStar 11 110w AT200? PREV FTA
TO 9464 ORDER MPEG2 HD Tp 10 EchoStar 11 110w AT200? PREV FTA
MOVE 9945 DVRDN UNKNOWN Tp 19 EchoStar 6 72.7w UNAVAIL HIDE
TO 9945 DVRDN UNKNOWN Tp 29 EchoStar 6 72.7w UNAVAIL HIDE
MOVE 9946 DVRVR MPEG4 SD Tp 19 EchoStar 6 72.7w UNAVAIL HIDE
TO 9946 DVRVR MPEG4 SD Tp 29 EchoStar 6 72.7w UNAVAIL HIDE
6 NAME CHANGE(S) (May include other changes as well.)
CHNG 4269 MHD MPEG4 HD Tp 19 Rainbow 1 61.5w AVAIL HIDE
TO 4269 PLDIA MPEG4 HD Tp 19 Rainbow 1 61.5w AVAIL HIDE
CHNG 4269 MHD MPEG4 HD Tp 19 EchoStar 5 129w AVAIL HIDE
TO 4269 PLDIA MPEG4 HD Tp 19 EchoStar 5 129w AVAIL HIDE
CHNG 5320 MHD MPEG4 HD Tp 19 Rainbow 1 61.5w AVAIL HIDE
TO 5320 PLDIA MPEG4 HD Tp 19 Rainbow 1 61.5w AVAIL HIDE
CHNG 5320 MHD MPEG4 HD Tp 19 EchoStar 5 129w AVAIL HIDE
TO 5320 PLDIA MPEG4 HD Tp 19 EchoStar 5 129w AVAIL HIDE
CHNG 9469 MHD MPEG4 HD Tp 19 Rainbow 1 61.5w AVAIL HD MAP 369
TO 9469 PLDIA MPEG4 HD Tp 19 Rainbow 1 61.5w AVAIL HD MAP 369
CHNG 9469 MHD MPEG4 HD Tp 19 EchoStar 5 129w AVAIL HD MAP 369
TO 9469 PLDIA MPEG4 HD Tp 19 EchoStar 5 129w AVAIL HD MAP 369
TRANSPONDER CHANGES
CHANGE Tp 1 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 1 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 2 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 2 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 5 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 5 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 6 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 6 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 8 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 8 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 9 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 9 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 11 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 11 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 14 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 14 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 15 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 15 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 16 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 16 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 19 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 19 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 21 EchoStar 11 110w ,QPSK SR 20000 FEC 3/4
TO Tp 21 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 22 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 22 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
CHANGE Tp 24 EchoStar 11 110w ,QPSK SR 20000 FEC 5/6
TO Tp 24 EchoStar 11 110w ,QPSK SR 20000 FEC 7/8
94 CHANGE(S) 5500 CHANNELS IN THE SYSTEM
Can someone explain to me the Tulsa moves? I looked through it twice and didnt see any difference except for the mapping.
Mapdown type change is all. Not known what it does, but this type of change caused WSBK Superstation to show on channel 38 of those subscribers to Superstations. In this case it should not cause a problem.
Mapdown type change is all. Not known what it does, but this type of change caused WSBK Superstation to show on channel 36 of those subscribers to Superstations. In this case it should not cause a problem.
Thansk JohnH...!
Made my morning when I saw Tulsa make the uplink report, sure was hoping this was a step in the right direction to Tulsa HD locals...:(
The change is because MTV-HD, VH1HD and CMT-HD are coming and will (FINALLY) have real HD content. So MTV netorks is building this new brand to showcast live concerts.
I would have liked it if they called it RAVE myself. :D
Ditto to that - I really miss the RAVE channel - watched that one the most - it was like being at a concert but without all the people & drunks!
as long as they have more variety, Rave just had like 10 things they showed over and over.
Can some one give me a quick course on what the benefit of the FEC change? Thanks.
I like no logo so the new logo is better, the previous MHD logo was one of the the most disturbing things I have ever had to endure. Now I can enjoy this channel without that much distraction, just hope the music content stays good.
Thanks JohnH...still no power in the war zone in my area....really bad down here. Gustav smashed this area good. Power company says this is the largest outage on their record books.
Jacmyoung,
FEC stands for Forward Error Correction. Basically, there is a bunch of Error Correction code built into the BitStream to make up for missing or degraded bits. The Ratio 5/6 means that only 1 bit out of six is being used for Error Correction. This means the Higher that ratio the more usable bandwidth there is for the actual content. Dish might change the FEC ratio to 7/8 on the transponders from the new Echostar XI satellite because of its higher Radiated power.
John
Similar threads
