USALS Coordinates
ChuckBoozer
253
South Carolina
Just a quick question for the group:
Which set of coordinates should be entered into USALS - the degrees/minutes or decimal format? Since the numbers are so close, does it make much of a difference?
Chuck
Thanks for the reply, Ice.
I also use my decimal coordinates, rather than the degree/minutes. Works fine for me, but I was just wonderin...
As an aside, but related topic, it's quite permissable to "fudge" those numbers a bit if you find it gives you a better quality signal. I'm in a high wind area, and those lake breezes have been subtly changing my azimuth adjustment. Oddly a few weeks later, it gets changed in the opposite direction. Fiddling with the longitude number can keep you from having to visit the dish quite so often.
A FTA use for Dish and Bev!!!
DiseqC Switch Questions
