Used Satellite Dish
Sheltiemom
6
Wisconsin
I purchased a Dish Network Superdish and want to know if it will work with an HD TV. We bought it on Craigs List and want to use it up north at our cottage.
no
The Superdish sees either 105/110/119 or 110/119/121. 105 & 121 are not used anymore. There is a SD upgrade kit I think that gives you 110/119/129
Can you post a pic of it?
If it says "Superdish" on it then it wont get HD
Here you go.
yeah that will see 105/110/119 I think. The picture is a little small but on the LNB if it says "HDTV" then its the 105 SD
Dish thought about putting HD on 105 years ago but scrapped that idea
Get a Superdish kit for $99. from Dishstore.
The Dish Store - Powered by Metro25
But you'll need another lnb for 129, with all the costs involved it would be cheaper and easier to get a modern dish such as 1000.2 or 1000.4
I would suggest you call Claude @ Dishstore.net about your purchase and see if you can get those receivers activated etc ...
Here you go.
That picture is a 121 superdish. Gets 110, 119, 121 if you're lucky. If you aren't lucky, the LNBs are old and out of tolerance and it gets nothing.
looks like an old 301 or 311, and a 111 receiver with it.
Did you check under the plastic cover for wasp's?? That is a common problem here and I'm sure other places, come across one of these antiques in the field, first thing you do is spray it with wasp killer. I have seen some nest's that are as big as the inside of the cover!! I'm so glad we don't see too many anymore.
Questions Before Making the Switch to Dish
Timer wouldn't stop recording
