VHF low antenna needed
SatPhreak
944
143
Thunder Bay, ON
Does anyone one what I can use as an antenna for my local channels. My locals are all on vhf 2,4, and 9. I tried a cheap antenna and I can only get 4 and sometimes 9.
Mr Tony
3,653
15,942
Mankato, MN
are you in Thunder Bay proper or outside of city limits?
Since both CKPR & CHFD are on VHF Lo (2 & 4) you need one of the "old school" antennas that can get VHF Lo
Do you need an indoor antenna or can you use an outdoor one? IF you can do outdoor this is the cheapest one I see on Solidsignal. Its a VHF only antenna which is all you need in TB
http://www.solidsignal.com/pview.as...F-FM-HD-TV-Antenna-(CS600)&c=TV Antennas&sku=
Mr Tony
3,653
15,942
Mankato, MN
yeah the one I linked to should work fine then
good lord. I just looked and they are running both stations with 1200 watts? Damn....stations here in the states on VHF low are running much more (15-30,000 watts). I guess other than TB proper they really dont need to cover any other area
Mr Tony
3,653
15,942
Mankato, MN
It also looks like ANT751 is HI VHF only less than 1 meter wide.
but again....2 things
-the specs say UHF also
-If its truly VHF Hi it wont work as the OP REQUIRES VHF low. 2 stations are on VHF low (2 & 4) so he needs a full VHF antenna
UHF, VHF High, FM Antenna
WPTZ Burlington New Sub Channel
