Viewsonic Remote Codes 622
View Sonic Code for Dish
Hello All, I was checking around for a View Sonic TV code elsewhere on the Net and ran across an item that indicated that the TV codes for Phillips will work for Dish receivers as they (the Dish Receivers) have Phillips tuners inside them. Author said the Phillps codes worked for him but as always, individual results may vary. Hope this helps. Gary
I don't know if this will help, but I have a Viewsonic TV Model N1630W and a Dish DVR 722... I was able to use code 818 in the remote to control the TV. Power, volume, mute, keypad worked... I found lots of codes that turned the TV on and off, but this is the only one that also controlled the volume.
Don't know about satellite boxes but remote control code 10054 works (somewhat) with my Comcast cable set top box's controller and my N1630W ViewSonic TV. This code should also be compatible with: N1930W-2 N2230W N2230W-2 NX1932W NX2232W VT2430-1M (ViewSonic controller part number A-00008204)
For information the ViewSonic parts store (store.viewsonic.com) stock replacement parts such as remote controls for their TV's and other devices. However, the link to the proper "Store" page isn't the one found on their main page. Only after emailing them and waiting 3-weeks for a reply I was told to use (store.viewsonic.com). Also, users cannot search for parts unless they register first
Strange, doesn't work on my 322 remote. Power only...need volume!
Lex
You may need to get the new 21.0 learning remote. I ordered 3 of 'em to control my Olevia TVs--one for my sisters'. You can order one by calling Dish. The CSR said they wouldn't work with my 622 & 722 but she's WRONG. Another member of this forum is using one with his 622 and the last Dish Tech Forum said they would work. I'll post when mine arrive. Should be here mid-week.
Ed
Remote code for the Viewsonic N2201w
For what it is worth the 622 remote code 834 will work with the ViewSonic N2201w. This gives you POWER, VOLUME, and Mute.
At first I tried the 818 code someone mentioned above. It didn't work for me, so I started other codes starting above 818. In about 30 seconds I was pleased (and suprised) to find a code that worked.
I am controlling the ViewSonic with the UHF TV2 remote so I would have been unable to use a standard Learning remote. The new programmable learning remote 21.0 mentioned above should do the job for most TV's if you can't find a code that works.
Model Number N3250w
I tried the auto find with no luck
Thank you for contacting ViewSonic Technical Support.
I understand that you are looking for remote codes for your unit. I care about your concern and I am glad you took the time to contact us.
Please refer to the user manual from your service provider to determine the settings. If it requires:
3 digits, please try 566, 565, 556, or 688.
4 digits, please try 0054, 1627, 1755, 0864, 0857.
5 digits, please try 11454, 11054, or 10690.
Here are another codes you may try: 0113, 0001,0003,0011,0040,0060,0067,0088,0132,0145, 0148.
If none of the codes listed work, please contact your remote manufacturer for further assistance. Or Parts department at 1-877-878-8673 between 6AM-5PM PST, Monday through Friday.
FYI - Diplexers adversely affect Moca signal strength
Tailgater First Impression
