mebgardener said:
I'm not sure if there is a bug with the Caller ID function or it may be my mistake but the Caller ID doesn't seem to work. I've received numerous calls today and the Caller ID did not appear on the screen. I enabled the Caller ID by doing the following: Menu->System setup->Installation->Caller ID->Enable Caller ID.
Anybody experiencing this problem?
When you open the system info pages, it tests your phone line/connection. Not the menu-menu system info single page, the system info pages (3) in the installation menu. It does it during the status check on page 1.
There is also another menu area specifically for testing the phone line/connection.
I can't remember where.
Check that first, and make sure your 622 is seeing the phone line as being connected.
Be certain you're plugged into the phone jack, and not the ethernet port. I did that when I installed my 211, dispelling the rumors doing so can fry your receiver or phone system. I connected it correctly, and it has worked fine since.
