VS Ultra / Gbox 3000 Positioner Install
megahurtz
[FONT=&quot]Has anyone successfully married the VS2000/Gbox and linear actuator? I resurrected the old BUD to put it up on FTA. I was able to control the dish through my STB fine until I ran across the motor set-up menu, I fiddled with the limit settings and now the dish does not move when I command through the STB. Every this is fine when I use the G-Box direct. The VS manual is very poor and does not mention the motor set-up menu. Please advise.
:eureka
[/FONT]
its possible you set the limits together or so close it won't move do a limit reset (or delete the limit) ( i think you can do this from either the gbox or from the VS menu) and this should cure your problem
FTA Receiver..?
Motorized receivers: do any display status as moving?
