Wally signal loss
Doughhead
23
4
Western desert
My RV Wally receiver has quit. I have it connected to a full size dish, western lnb.
I have been testing the signal. My cheap satfinder tells me I should have 13 to 18 volts.
This must be from the center pin to the swiveling nut? Mine is 0 volts, at the Wally.
Am I testing correctly?
"MY Wally receiver has quit." doesn't tell us much.
Is the receiver totally dead?
Has it lost satellite connections?
Does it display any picture at all on the screen?
Any error messages if there is a picture?
Direct connection of a Simpson Meter may not tell you what is happening if the circuit won't send current until a certain load is detected.
What diagnostics have you done?
Ok. The screen says complete signal loss. I have tried a spare lnb. My satfinder says I should have 13 to 18 volts in the coax cable. I have 0. I tested at the Wally. Could the Wally be toast? I am a beginner at this.
Thanks.
Thanks.
If there's no voltage on the satellite port of the Wally then it sounds like the Wally has a problem. You can try unplugging it for half an hour or so and trying it again. If it still has no voltage at that point then it probably needs to be replaced.
New Software Coming Tonight
What happened to Smithsonian, Ch 367?
