What channels do you have trouble with
Blindowl1234
2,035
94
SouthWest Ohio
Ok its friday! So lets have some fun. What channels do you have a tough time getting where you live? Rtn right now is a given for many
C band woes-
133W AMC 11 - 3910 V 13200 - Was a solid 70+Q up untill recently, now there is absolutely nothing. Big fat zero.
105W AMC 16 - 3920 V 30000 - Was aslo a solid 70+Q, Now hoovers around 50, Too weak to lock.
I've tried shifting the freq/SR. Checked dish alignment and operation across the arc. It's good, and normal Q's, except for these two.
Thought it may be freq/SR related but many other TP's with same or nearly same freq/SR are locked. (????)
Some feeds seen, in the eastern states/shore on 55W, I just don't see. But everything else is great.
Ku band- 127W, H1, rarely get anything on that one. I blame it on a nonfavorable footprint and a 30 inch dish.
85W, AMC 16, Somewhere around 20 to 30% of feeds are not seen. The rest BOOM IN.
EDIT: RTN @ 87W, forgot this one because I have given up on it. IT'S NOT WORKING.
I had trouble with the RTV channels on ku band 87w they gave me a hard time with my slimline. can't pick up anything on c band since I live in an apartment and don't have a c band lnb.
Dan Rose
RTV on 87W C-Band
Alaska mux on 137W.....for some reason this year its real low signal
on KU really can't complain....dont have issues getting stuff
I lost all RTV C band on 87W several weeks ago :(
Everything else is fine though. Guess I need to go out and ush on it. My rebuilt jerry-rigged actuator has a lot of play in it
NBC channels on AMC1 w/ that funky skew. Tried every skew positions and did swap LNBs. Am startig to thik these channels dont exist and am just being punked by you guys
Cheers, K
Well the only problems I have is with RTV (i.e. Luken mux) on Ku, but now the problem is limited, the channel is perfectly watchable around until noon then the picture starts breaking down and pixelating and remains like that until the next day, while the Q will show bouncing numbers all the time.
DVB-S raw stream needed for testing - please help!
Openbox S10 continuous reboot fix
