Just curious, what should I do with my extra Dish 500, and 18" Dish and RCA DSS antennas? Are they good for anything? Thanks in advance!
iafirebuff said:Just curious, what should I do with my extra Dish 500, and 18" Dish and RCA DSS antennas? Are they good for anything? Thanks in advance!
voomvoom said:Well, I for one believe in change. I remember when it was impossible to have/use a dish as small as 18". Then came stronger satellite's, as well as better electronics. Who's to say they won't make even stronger satellite's, except this time for regular ku instead of DBS, so we would be able to use all these 18" dishes laying around. Who knows what's in store?
Al
Iceberg said:119 & 91 have most of the audio channels. It is very possible to set it up that way. The only issue is you have to use either DirecTV LNB's or the older Dish Legacy LNB's.
You can't use a Legacy Twin (the bigger LNB). The receiver doesn't know how to deal with it. I know you can use a DishPro, but there is some changes to the setup you need to do.
I have a dish at 119 and a dish at 91 connected with a 22k switch (its an old 4x4 multiswitch). This way I only need to tie up one Diseqc port and can get 2 different dishes (its set up as port 4 22k on for 119 and port 4 22k off for 91)
If you want to use all 4 satellite slots, you could but that would take up all 4 ports of the switch
Iceberg said:.....
norman said:Ice,
Are you talking about using the OLD Direct tv dish & lnb hooked to a FTA receiver?
I have a close friend that has NO FM at her greenhouse. So I was thinking about putting one up.
I do know that if you use a turned off dish system that the preview ch plays some perty good jazz.
Norman
