Whats need to add 3rd TV to a 722 system?
ron2nd
7
I recently joined Dish and got a 722 with a 3 LNB dish that is hooked up to a standard def tv in the bedroom and a High Def TV in the living room. I did not expect to have to hook up the standard TV in the spare bedroom but need to do that now. What is the cheapest way to get standard def reception to this 3rd tv that was never hooked up to the dish? What reciever do I have to get and how to hook it up and I am sure this will cost addtional from dish right? thank in advance.
If you can live with the same programing on bedroom 1 and the spare bedroom, you can just split the TV-2 output, run a cable to the spare bedroom and buy a second TV-2 remote control. If you want separate programing you'll need an additional receiver and installation.
The additional SD receiver will cost $5.00 per month and whatever they charge you upfront. They will usually add a receiver for about $50.00 but that varies depending on current specials. Give them a call and check.
How current is Superdish.
What type of amplifier will I need on a 300' cable run
