why aren't C and Ku separated?
can you setup a custom lnb setting ?
if your using a 22khz switch to switch cband / kuband then use the cband with 22khz off port and ku with 22khz on port
lof/l 5150
lof/h 10750
threshold 11700
if your using a 5x8 and a dual ortho you can setup the same. then you can have cband and ku on the same sat entry.
Thanks. I tried to import satellite lists from crackt post and it wouldn't work for me. I kept getting all the Euro stuff right back.
Boomer after you select the Sats you want to save from the .xml site go to the bottom of the right side of the List and there is a code number you have to type in and then the List will be saved, and you can DownLoad the List to your Computer.
Thanks jsat. I ended up doing mine by remote. I now believe I can recover quickly from corruption.
