Winegard dish declination angle
galiman
11
Hello,
I have a 31" Winegard dish and an SG2100 motor. I live in the deep south, lattitude 30.4N. According to SG2100 directions, declination angle for dish should be set to 25 (30 - 5). But when I try to change the angle of the dish, the lnb support arm where it bolts to the rear of the dish strikes the motor post, allowing me to move the angle only to 30 or so. Anyone know of a work-around for this, or am I doing something wrong. Thanks for you help.
Any pictures?
If its a nut or bolt you may be able to reverse it.
I am at Lat. 45 with the elevation at 23 deg. for the dish elevation install a LOAD without a problem?
Maybe you are in the wrong hole of the motor shaft?
Are you using a Winegard dish? The elevation scale on my dish only goes to 25.
I think what the deal is, I haven't noticed the red line used for setting angle. I've been trying to use center of bolt. Am at work now, but will check it out as soon as I get home.
Thanks PSB,
Galiman
Scanning for HD
Looking to track a bird on inclined orbit
