Winegard dish pointing, help !!!
crazychris
I have a Winegard 76 assembly. It is the 31" dish on a Diseq 1.2 motor. My zip code is 35805. I am a bit confused about setting the correct angles. The motor scale says Latitude on one side and Elevation on the other side. Then there is the dish bracket angle, it does not seem to be to adjustable because it hits the motor when dish is tilted back. Any help would be greatly appreciated !!!
Motor Elevation = 55º
Dish on motor elevation = 24º
AMC-3 is your true south satellite..........
Code:
                     Huntsville, AL 35805
         Latitude 34° 42.354'N Longitude 86° 36.990'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                     Telstar 12   15.0W 100.7 103.6  6.4 -53.9
                   Intelsat 901   18.0W 102.6 105.4  8.8 -53.4
                          NSS 7   22.0W 105.1 108.0 12.1 -52.5
                   Intelsat 905   24.5W 106.8 109.6 14.2 -51.9
                   Intelsat 907   27.5W 108.8 111.6 16.6 -51.1
                  Hispasat 1C/D   30.0W 110.6 113.4 18.7 -50.3
                   Intelsat 801   31.5W 111.7 114.5 19.9 -49.8
                   Intelsat 903   34.5W 113.9 116.7 22.3 -48.7
                    AMC 12/T 11   37.5W 116.2 119.1 24.7 -47.5
                        NSS 806   40.5W 118.7 121.5 27.0 -46.1
                      Pas 3R/6B   43.0W 120.9 123.7 28.9 -44.9
                         Pas 1R   45.0W 122.7 125.5 30.4 -43.8
                   Intelsat 705   50.0W 127.5 130.3 34.1 -40.7
                   Intelsat 707   53.0W 130.6 133.4 36.2 -38.6
                   Intelsat 805   55.5W 133.3 136.2 37.9 -36.7
                          Pas 9   58.0W 136.2 139.1 39.5 -34.7
                       Amazonas   61.0W 139.9 142.7 41.3 -32.0
                     EchoStar 3   61.5W 140.5 143.4 41.6 -31.5
                      Rainbow 1   61.5W 140.5 143.4 41.6 -31.5
               Estrela do Sul 1   63.0W 142.5 145.3 42.5 -30.0
                   Brasilsat B2   65.0W 145.2 148.0 43.5 -28.0
                   Brasilsat B1   70.0W 152.3 155.2 45.9 -22.4
                       Nahuel 1   71.8W 155.1 157.9 46.7 -20.3
                      DirecTV 1   72.5W 156.2 159.0 46.9 -19.4
                          AMC 6   72.0W 155.4 158.2 46.8 -20.0
                          SBS 6   74.0W 158.5 161.4 47.5 -17.5
                     Echostar 4   77.0W 163.4 166.3 48.4 -13.6
                          AMC 5   79.0W 166.8 169.6 48.9 -10.8
                      Nimiq 2/3   82.0W 171.9 174.8 49.4  -6.6
                          AMC-9   83.0W 173.7 176.5 49.5  -5.2
                   Brasilsat B3   84.0W 175.4 178.3 49.6  -3.8
                          AMC 2   85.0W 177.2 180.0 49.6  -2.3
                          AMC 3   87.0W 180.7 183.5 49.7   0.6
                           IA-8   89.0W 184.2 187.0 49.6   3.4
                      Galaxy 11   91.0W 187.7 190.5 49.4   6.3
                     Nimiq 1/4i   91.0W 187.7 190.5 49.4   6.3
                   Brasilsat B4   92.0W 189.4 192.2 49.3   7.7
                           IA-6   93.0W 191.1 194.0 49.1   9.1
                      Galaxy 3C   95.0W 194.5 197.4 48.7  11.9
                           IA-5   97.0W 197.8 200.7 48.2  14.6
                      Galaxy 4R   99.0W 201.1 203.9 47.6  17.2
                     Spaceway 2   99.2W 201.4 204.2 47.5  17.5
                DirecTV 1R/4S/8  101.0W 204.2 207.1 46.8  19.7
                          AMC 4  101.0W 204.2 207.1 46.8  19.7
                     Spaceway 1  103.0W 207.3 210.2 46.0  22.2
                          AMC 1  103.0W 207.3 210.2 46.0  22.2
                         AMC 15  105.0W 210.3 213.1 45.1  24.5
                      Anik F1/R  107.3W 213.5 216.4 44.0  27.0
                      DirecTV 5  109.5W 216.6 219.4 42.9  29.3
                EchoStar 6/8/10  110.0W 217.2 220.1 42.6  29.8
                        Anik F2  111.1W 218.7 221.5 42.0  30.9
                  Solidaridad 2  113.0W 221.1 223.9 40.9  32.7
                       SatMex 6  113.0W 221.1 223.9 40.9  32.7
                       SatMex 5  116.8W 225.6 228.5 38.5  36.0
                         AMC-16  119.0W 228.1 230.9 37.0  37.7
                     DirecTV 7s  119.0W 228.1 230.9 37.0  37.7
                     EchoStar 7  119.0W 228.1 230.9 37.0  37.7
          EchoStar 9/Telstar 13  121.0W 230.2 233.1 35.7  39.2
                     Galaxy 10R  123.0W 232.3 235.1 34.3  40.6
                      Galaxy 14  125.0W 234.3 237.1 32.8  41.9
                  Galaxy 13/H 1  127.0W 236.2 239.0 31.3  43.1
 Intelsat Americas 7/Echostar 5  129.0W 238.0 240.9 29.9  44.2
                         AMC 11  131.0W 239.8 242.7 28.3  45.3
                      Galaxy 15  133.0W 241.5 244.4 26.8  46.3
                         AMC 10  135.0W 243.2 246.0 25.2  47.2
                          AMC 7  137.0W 244.8 247.6 23.6  48.0
                          AMC 8  139.0W 246.3 249.2 22.1  48.8
                   EchoStar 1/2  148.0W 252.7 255.6 14.8  51.7
       Satellite Finder is (c) Copyright 2004, P. Lutus
Make sure you are using the RED mark on the dish for the elevation :)
Iceberg said:
the motor elevation is the same as your latitude (use the side that says latitude)
Actually the Elevation is equal to 90 degrees minus your latitude. Example If your latitude is 34.42 the elevation is (90 - 34.42 =) 55.58 degrees
One side of the scale will be set to read the actual latitude as Iceburg stated and the other side will read the elevation which can be calculated as above ..... Confusing .... so just use the Latitude scale as Iceburg suggests.
Need help with Coolsat settings
Thank you for the help getting my dish set at right angles. Now that I'm that far I could use some help on knowing how to set up Coolsat 5000. I have the Invacom Quad Polor Legacy 4 LNB , the C is going into port 1, and L into port 2 of a Pansat 4by1 diseq switch, and the output going to the Diseq 1.2 motor. Do I need to go into Dish Setting or Motorized Setting and what would be the correct settings ?
Dish settings, but I would not set up the switch for now, just something else to get in the way! I would wait until you are all lined up with the Linear satellites first, again I would only use one L output to start on the Invacom QPH-031
Make sure your L.O. is set to 10750 for the L output!
ok, I took the switch out, now I am using only one of the L outputs from the QPH-031 that goes into the Diseq 1.2 motor and into the CoolSat5000. I am under Dish Settings in the menu, let me confirm my settings.
Satellite - 87.0W AMC 3
LNB Power - on
LNB Type - Legacy Quad LNB2
LNB Frequency 10.750
22khz - off
Diseq Switch - off
Legacy Switch - off
With these settings I am still not getting more than 73% on level and 5% on quality. I have double checked my angles which are set to 55 for the motor and 24 for the dish bracket.
Can you pick up the GOES satellites?
Quick Question - Pole in Bucket?
