Wing Dish Question.
66mustang
151
5
Greeneville,TN
Anyone have any luck using a Dish 500 as a wing dish for the 129 bird? I already have a Dish 500 with a DPP LNB and a 500 with no lnb. The 129 is not that great where I'm from. Just wanting the best possible signal. After hearing all the war stories about the 1000.2 and the 129 it made me curious.
Should work. An I yoke is even better to center the LNB in the dish.
You will need a Dish Pro Single or Dual LNB and an "I" adapter.
Where are you located? 129 should be fairly easy to pickup. I have in the past put 1 LNB into one side of the "Y" yoke and a twin in the other ( with one end sticking out to side) and could get 109, 119 and 129. But as noted, it works well with a standalone 500.
Sent from my iPhone using Tapatalk[/Q
I'm from Greeneville,TN. The 129 bird is tricky in my neighborhood due to so many tress.
I use a single LNB with I adapter, works fine for me, but I had a heck of a time finding signal because of trees. In fact I had to go to opposite end of house from my other dish.
Dan
Until this summer, I was right up the road from you in Johnson City and used a 500 as a wing dish to get a better signal for 129. I had a 500 with a twin for 110 and 119 and a 500 with an I adapter and a single. All ran to a DP34 switch, then into the house.
Dish's Ergen considers bid for T-Mobile if Sprint deal fails
Two Year Contract Buyouts- Consumer Beware
