world direct dish to modulators
cyberdish7
nc
I need to install a world direct dish to get mandarian channels for commercial location. What are the coordinates for raleigh durham nc 27604? also do you just lock in 101 first even though its not needed? then i run 2 lines to my 6x 8 switch one from 101 and one from 95 then from switch to recs then connect recs to modulators. thanks
Well first of all, you MUST run 2 lines from 101 to the switch - obviously the 1 from 95 is ok.
And actually, the 101 IS still needed on the current receivers, as they need 101 to boot up on.
I don't know the coordinates, but the way I would be doing this, is to get the dish aimed correctly for 101, THEN connect the 95 coax DIRECTLY to your meter or receiver & make sure it's peaked on 95. Then, connect everything back up as I just described.
Swm LNB
Can drilling holes be avoided?
