Would this switch configuration work?
Paradox-SJ
1,636
San Jose, California
-Hardware-
Switches: DP34 and 2 DP21
Dish/lnb's: Dish500 w/DishproTwin and 2 Dish300 with Dishpro Single
Connect Dish500 (110/119) and Dish300 (148) to DP34
Connect Dish300 61.5 to Dish approved splitter
Connect DP34 port 1 to DP21a
Connect DP34 port2 to DP21b
Connect split 61.5 to DP21a and DP21b
You now have two lines with 4 satellites…
Will this work as it is cheaper than buying a DPP44
Paradox-SJ said:
-Hardware-
If it was that simple do you think DISH would design a DPP44? Others have proven that it won't work, the problem is the receivers will recognize the 4th satellite but won't switch to it. :)
Actually, E* added the logic for this back in the summer. As long as the DP34 is on port 1 of the DP21, it should work fine. This was posted by justalurker over on dbstalk:
My DP21 came, the SD105 will be here Monday, but that doesn't mean I can't play a little.
It will work in the previously discussed mix:
DP34 -> DP21 Port #1 & 61.5 -> DP21 Port #2
DP21 -> 501
Check Switch finds all (1=DP34p1, 2=DP34p2, 3=DP34p3, 4=DP21p2)
Channels are actually tuneable.
Real nice to have a cheap alternative to the DP+44. At this point DP34 + 4x DP21 seems to be cheaper than DP+44's.
We just did an install where we tried this and NO GO. It didn't work at all and I spent 3 hours trying to get it to work.. Don't waste your time. Just buy the DPP44.
Shawn
I did every combination and it doesn't work. I agree I would think that it should work but it just doesn't. I was using a DP 301 with current software and it just wouldn't work. Put in the DPP44 and everything works like great.
SimpleSimon, Well it didn't work for me and I have been doing installs for 4.5 years and I tried everyone of the combinations possible. I don't understand why it may have worked there but it didn't work here. Like I said I was using a 301 with current software a 105 Superdish and 61.5. I tried every combination because I had read that thread but after three hours and nothing working I decided that it didn't for me.
Give it a try it may work for you. I hope it does. It is a cheaper option than a DPP44. I just giving my account on what happened and I couldn't get it to work.
Good luck.
By the way I started with the way the diagram stats and it only saw 3 sat. I also changed out the DP34 and the DP 21 to make sure I didn't get a bad switch.
All I'm saying is that it didn't work for us. I truely felt bad for the customer. I did give her credit on the DP34 that came with the superdish and her legacy equipment. So it was as bad as it could have been.
DISH and Local HDTV
Dish DVR 510 Cuts off lasts mins of Program
