WS International DMX522 Dual Linear, Standard Ku LNBF
WSInternational
370
Los Angeles, CA
Our DMX522 Dual Ku Band Linear Ku LNBF is now back in stock. ​
Technical Specifications
Input Frequency Range 11.7 - 12.75 GHz
L.O. Frequency 10750MHz
L.O. Stability 1 MHz (-40 - +70° c)
Ouput Frequency Range 950 - 1450 MHz
Noise .2 dB typical
Conversion Gain 70 dB typical
Input VSWR 2.5:1
Output VSWR 2.0:1 (max)
Connector F Type female
Impedence 75 ohm typical
Cross Polar Isolation >25dB (min.)
Image Rejection 45 dB (min.)
Phase Noise -50dBc @ 1 KHz
-75dBc @ 10 KHz
-95dBc @ 100KHz
Supply Voltage
Ca: 11.5 - 14.0 V = Vertical Polarization
Cb: 15.5 - 19.0 V = Horizontal Polarization
Operating Temperature -40 - +70 degrees Celsius
Storage Temperature -40 - +80 degrees Celsius
Relative Humidity 0 - 95 %
Throat Diameter 40mm
This is a Dual Linear Ku band LNB. It's compatible with all the DiSEqC & Multi switches on the market and with an incredible, first ever 0.2dB noise figure, it will give you the highest possible quality signal.
Works excellent if you want to upgrade your Free To Air and/or Ku band satellite system to add additional satellite receivers.
WS International is the original manufacturer of the DMX522 Ku band satellite LNBF
Need to order in large quantities? WS International can private label this LNBF for you!
Buy Retail @ www.galaxy-marketing.com For Only $20.95+shipping.
Buy Wholesale @ www.wsidigital.com & install, and sell the best selling dual ku band LNBF on the market today!!!!
Not an Authorized WS International reseller? It's easy to become a WS International Reseller. Click Here Now
Glad to see you got those restocked.
Need to get some reviews posted.
Send one to Iceberg, and see if Linuxman will take one.
Ice'll find some imaginative way to use it. Something I'd never think of! - :cool:
Linuxman needs the dual output, and has a bunch of SL2's in his array already!
I have one ;)
other than using it when I originally tested the 1.2m dish on KU I havent found a use for it. I might put it on the 2nd motorized setup I have (if I can get on the roof some night......aint going on it during the day...too warm) :)
What ever happened to Safe TV and Familyland ?
Ku lnbf on C band feed.
