WS1247-120cm-1 offset Ku dish
jibaro29
377
12
Lake Worth FL
Hi guys,
I have a couple of questions concerning this Ku dish. First, Would I be able to get C band using DMX741U lnbf? And,What type of bracket would I need for my SG2100?
Thanks:rolleyes:
guapoharry
1,423
32ºN 111ºW
Does the dish mount look like this?
What is the diameter of the pole?
Mr Tony
3,892
16,982
Mankato, MN
the SG2100 isnt really compatible with a 120cm dish...they claim it but you need a dish that is very very light
A HH120 would probably be able ot motor that dish around and since the HH120 has the shaft up (versus the SG2100 where its down) the dish could probably be left as is with no modifications
WSInternational
370
Los Angeles, CA
The outside dimension of the mount is 3 inches and the inside dimension is 2-7/8 inch in diameter.
Iceberg is right. You will need to use the HH120 made by STAB. Besides the fact that the HH120 is a stronger motor, the way the back bracket of the WS1247 1.2m dish is designed, no other motor will work with it except for the HH120.
There are two U-bolts that will tighten around the shaft of the motor. Unlike the SG2100 or SG6000 that are manufactured for dishes "up to 1.2m" but are realy ment to be used on smaller dishes, the HH120 is designed specifically for a 1.2m dish. STAB HH100-HH120
B.J.
2,029
Western Maine
I'm curious what the logic is re upward vs downward shaft. Intuitively, it seems to me that a downward facing shaft would have an advantage over an upward facing shaft, because the downward shaft allows for the dishes center of gravity to be closer to the rotation axis, requiring less torque to move it. Plus it seems like the downward shaft would be more water-proof.
Anyway, I've never thought much about it before, so I'm curious what the advantage would be for an upward facing shaft?
jibaro29
377
12
Lake Worth FL
It looks like my some what low budget project just got a reality check. I checked on line and the price for Stab 120 goes for around $135.00. " Where is my stimulus package". I sure could use one right about now. :mad:
Anole
11,819
14
L.A., Calif.
some options:
The less-expensive Sadoun-supplied DG-380 motor will swing a 1.2m dish, but it has a downward-pointing dog-leg shaft.
The STAB HH-120 is the only obvious (H-H) solution for the WSI dish.
Double check that the dish mount will fit the shaft of any motor chosen.
If you look at the Fortec Star 1.2m or the GeoSatPro 1.2m dishes, they'll fit the 380 motor just fine.
Actually, the GeoSat 1.2 mounting bracket allows for top or bottom entry, should it be convenient.
... the Fortec may, as well...?
daddyzlod
72
Birchwood,Wisconsin
Just ordered, and received 2 wsi 1.2 meter dishes from galaxy-marketing this last week, and they came in with the best shipping price of $129.00, versus sat av at $215.00, and sadoun at $377.50.
Doing some changes here to the dish farm.
Bob
WSInternational
370
Los Angeles, CA
I believe the Fortec 120cm does allow for both top or bottom entry as well. :up
Mr Tony
3,892
16,982
Mankato, MN
jibaro
I just got my 120cm dish that you posted above and you most definitely would need a HH120 for a couple reasons
-there is no way a down shaft motor will work due to the oddball bracket for elevation
-this is one heavy mother....and the brackets are very heavy
Sadoun
2,320
Columbus, OHIO
Both have metal gears and heavy duty mounting brackets.
Sadoun PowerTech DG380
[FONT=Verdana, Arial, Helvetica, sans-serif]Rotation speed[/FONT] 1.9° / sec (at 13V) ; 2.5° / sec (at 18V)
Azimuth Angle 80° East ~ 80° West ( 160° )
Stab HH120
[FONT=Verdana, Arial, Helvetica, sans-serif]Rotation speed[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] 0.4°/s(13V), [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]0.7°/s (18V)[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
[/FONT]
Azimuth Angle 62° East ~ 62° West ( 124° )
FTV to end SD signal, will be HD only
Coolsat 8000 programming
