Can anyone tell me what is the difference between these two LNBF. The specs looks the same to me.
[FONT=trebuchet ms,arial,helvetica][/FONT]![]()
[FONT=trebuchet ms,arial,helvetica]Input Frequency[/FONT][FONT=trebuchet ms,arial,helvetica]11.7~12.2 GHz[/FONT][FONT=trebuchet ms,arial,helvetica]Output Frequency[/FONT][FONT=trebuchet ms,arial,helvetica]950~1450 MHz[/FONT][FONT=trebuchet ms,arial,helvetica]Noise Figure[/FONT][FONT=trebuchet ms,arial,helvetica]0.3 dB typ.[/FONT][FONT=trebuchet ms,arial,helvetica]Gain[/FONT][FONT=trebuchet ms,arial,helvetica]62~66 dB[/FONT][FONT=trebuchet ms,arial,helvetica]Gain Ripple[/FONT][FONT=trebuchet ms,arial,helvetica]<5 dB typ.[/FONT][FONT=trebuchet ms,arial,helvetica]Local Oscillator Frequency[/FONT][FONT=trebuchet ms,arial,helvetica]10.750 GHz[/FONT][FONT=trebuchet ms,arial,helvetica]Local Oscillator Phase Noise (typ)[/FONT][FONT=trebuchet ms,arial,helvetica]1 KHz[/FONT][FONT=trebuchet ms,arial,helvetica]-65 dBc/Hz[/FONT][FONT=trebuchet ms,arial,helvetica]10 KHz[/FONT][FONT=trebuchet ms,arial,helvetica]-95 dBc/Hz[/FONT][FONT=trebuchet ms,arial,helvetica]100 KHz[/FONT][FONT=trebuchet ms,arial,helvetica]-110 dBc/Hz[/FONT][FONT=trebuchet ms,arial,helvetica]Local Oscillator Stability[/FONT][FONT=trebuchet ms,arial,helvetica]+/- 1 MHz[/FONT][FONT=trebuchet ms,arial,helvetica]Current Consumption[/FONT][FONT=trebuchet ms,arial,helvetica]< 100 mA[/FONT][FONT=trebuchet ms,arial,helvetica]Image Rejection[/FONT][FONT=trebuchet ms,arial,helvetica]> 40 dB[/FONT][FONT=trebuchet ms,arial,helvetica]Horn Type [/FONT][FONT=trebuchet ms,arial,helvetica]Offset[/FONT][FONT=trebuchet ms,arial,helvetica]F/D Ratio[/FONT][FONT=trebuchet ms,arial,helvetica]0.5 ~ 0.7[/FONT][FONT=trebuchet ms,arial,helvetica]Cross Pol Isolation[/FONT][FONT=trebuchet ms,arial,helvetica]> 20 dB[/FONT][FONT=trebuchet ms,arial,helvetica]Image Rejection[/FONT][FONT=trebuchet ms,arial,helvetica]45 dB (min.)[/FONT][FONT=trebuchet ms,arial,helvetica]Output VSWR[/FONT][FONT=trebuchet ms,arial,helvetica]2.5:1 (max.)[/FONT][FONT=trebuchet ms,arial,helvetica]Output Connector[/FONT][FONT=trebuchet ms,arial,helvetica]75 ohm F type female[/FONT][FONT=trebuchet ms,arial,helvetica]Operation Voltage[/FONT][FONT=trebuchet ms,arial,helvetica]11.5 ~ 14.0 V for Vertical[/FONT]
[FONT=trebuchet ms,arial,helvetica]16.0 ~ 19.0 V for Horizontal[/FONT][FONT=trebuchet ms,arial,helvetica]Operating Temperature[/FONT][FONT=trebuchet ms,arial,helvetica]-40ºC ~ +60ºC[/FONT]
[FONT=trebuchet ms,arial,helvetica]Input Frequency[/FONT][FONT=trebuchet ms,arial,helvetica]11.7~12.2 GHz[/FONT][FONT=trebuchet ms,arial,helvetica]Output Frequency[/FONT][FONT=trebuchet ms,arial,helvetica]950~1450 MHz[/FONT][FONT=trebuchet ms,arial,helvetica]Noise Figure[/FONT][FONT=trebuchet ms,arial,helvetica]0.3 dB typ.[/FONT][FONT=trebuchet ms,arial,helvetica]Gain[/FONT][FONT=trebuchet ms,arial,helvetica]50~62 dB[/FONT][FONT=trebuchet ms,arial,helvetica]Gain Ripple[/FONT][FONT=trebuchet ms,arial,helvetica]<5 dB typ.[/FONT][FONT=trebuchet ms,arial,helvetica]Local Oscillator Frequency[/FONT][FONT=trebuchet ms,arial,helvetica]10.750 GHz[/FONT][FONT=trebuchet ms,arial,helvetica]Local Oscillator Phase Noise (typ)[/FONT][FONT=trebuchet ms,arial,helvetica]1 KHz[/FONT][FONT=trebuchet ms,arial,helvetica]-65 dBc/Hz[/FONT][FONT=trebuchet ms,arial,helvetica]10 KHz[/FONT][FONT=trebuchet ms,arial,helvetica]-95 dBc/Hz[/FONT][FONT=trebuchet ms,arial,helvetica]100 KHz[/FONT][FONT=trebuchet ms,arial,helvetica]-110 dBc/Hz[/FONT][FONT=trebuchet ms,arial,helvetica]Local Oscillator Stability[/FONT][FONT=trebuchet ms,arial,helvetica]+/- 1 MHz[/FONT][FONT=trebuchet ms,arial,helvetica]Current Consumption[/FONT][FONT=trebuchet ms,arial,helvetica]< 100 mA[/FONT][FONT=trebuchet ms,arial,helvetica]Image Rejection[/FONT][FONT=trebuchet ms,arial,helvetica]> 40 dB[/FONT][FONT=trebuchet ms,arial,helvetica]Horn Type [/FONT][FONT=trebuchet ms,arial,helvetica]Offset[/FONT][FONT=trebuchet ms,arial,helvetica]F/D Ratio[/FONT][FONT=trebuchet ms,arial,helvetica]0.5 ~ 0.7[/FONT][FONT=trebuchet ms,arial,helvetica]Cross Pol Isolation[/FONT][FONT=trebuchet ms,arial,helvetica]> 20 dB[/FONT][FONT=trebuchet ms,arial,helvetica]Image Rejection[/FONT][FONT=trebuchet ms,arial,helvetica]45 dB (min.)[/FONT][FONT=trebuchet ms,arial,helvetica]Output VSWR[/FONT][FONT=trebuchet ms,arial,helvetica]2.5:1 (max.)[/FONT][FONT=trebuchet ms,arial,helvetica]Output Connector[/FONT][FONT=trebuchet ms,arial,helvetica]75 ohm F type female[/FONT][FONT=trebuchet ms,arial,helvetica]Operation Voltage[/FONT][FONT=trebuchet ms,arial,helvetica]11.5 ~ 14.0 V for Vertical[/FONT]
Yes, me too.I just wish theyd make it with dual outputs ...
