Come on Dish lets correct the guide issues with CW and Fox Charlotte. Its coming on 2 weeks since the change. You can't set OTA timers with the guide the way it is.
Dish still has not fixed this issue and its been about 7 weeks now since the change. I've reported this twice through DIRT.
I have had decent results sending an email to dishquality@echostar.com concerning the OTA programming guide.Good Luck!
P.S. First it might be a good idea to see if your HDTV guide has the program's information from your digital OTA tuner,if not you would need to send an email to the station in question.Good Luck!.
For existing channels, issues like that are usually sorted out through Tribune. When a station changes their network affiliation, their sub-channel's information (name, network, etc), good luck getting that changed, especially anything related to sub-channels.The guide data was correct before this transition took place about 7 weeks ago.
How long ago ?I have had more success dealing with guide data issues contacting "dishquality at echostar dot com" and explaining the issue. They took care of several issues including some sub-channel data for me in the past.
Thanks I just sent an email. This is not a station issue my TV sees everything correctly.
I received a response from dishquality@echostar.com. They said the issue has been forwarded to the proper folks and should be resolved in two weeks.
No, they won't. In that case, Dish specifically removed or turned off that guide data. When the dispute is resolved, they'll turn it back on.No guide info for ABC or FOX here, which DISH has been in dispute with forever. I'm sure it's a conscious decision that dishquality won't help with.
