sharing guide lists
oldanbo
59
Sequim, WA.
I came back to dish after 2yrs with the other. Anyway, I have a hopper w/sling and a super joey. I created a favorites in the guide list, but, I can't see it on the joey. Irritating to me. Is it not possible to share the favorites between the hopper and joey? Both are hardwired on my Ethernet home network.
So far, this is my only beef. I could go on and on about Genies/Direct but I may save that for later.
Any help/tips would be appreciated.
Thanks,
Dan
You could save the settings into the remote, take the remote to the Joey and pair it there, then transfer the settings to the Joey.
Favorites lists are specific to each receiver.
Reactions: navychop
Ohhh, I like the idea of moving the Hopper remote to the Joey and pairing it and then transferring! I never thought of that.... I knew that you had to, individually, set Favorites....
Thanks Lucky! Now...if I can just find the instructions........
While pair to hopper, press hold zero. Follow directions on screen. Once complete press system info on front of hopper. Select unpair. Take remote to Joey. Press system info on Joey, hit sat. Press and hold zero. Restore settings. Once complete with each receiver make sure the system info is not left up.
Thanks for that. Sorry to take so long to reply. I had an issue when I went to the Joey as I was offered an option to update system or remote. I think I erred by picking system, then I had to go through another bunch of stuff to get my remote paired back to the Hopper. But, it's done and it worked.
I thank you again,
Dan
ESPN ALT
SJ and joeys freeze up
