Tree being taken out?
Yammaha750
I am having a Tree cut and my dish is on a Pole near the tree and the tree service guys will not cut anything until it is removed.
I would have to take it off and then put it back, can I do this. How easy is it to remove and putting it back on? Do I need a compass or something or can I draw a line with a Black marker from the bracket to the pole then I could line it back up?
Your last idea is the way to go. When you replace the dish, you may need to readjust it slightly. Try putting two lines somewhat apart. That way you have more to reference.
yeah id use the second choice, shouldnt be that hard to do, maybe a little adjustment, but you should be able to handle it
Adding hr20????
Confusing terminology
