Can anyone confirm if this channel is still up? It was at AMC 4 101* W The freq was 11708 (V) 2170 SR. I keep saying " was" because I can't seem to tune it in. Even blind scan isn't pulling it up. Also "thelist" isn't showing this channel.
yes its still there...11706 V 2170
and yes the audio is WAY TOO LOUD!!
Sorry about that, I added it to TheList as KUIL FOX Beaumont 64.
Thanks.
LNB's are all different so I've seen it between 11705 & 11708
Are you sure you're aimed at AMC4?
KUIL is always a little buggy for me. I went out and pushed up on the dish a hair and it popped right in. Loudly![]()
After reading this discussion, I went and found this channel because I had not heard of it and it had not come up on a blind scan.
When I entered in the transponder info - it came in at 50% S and Q. (which is good/decent on this viewsat)
But as I watch it - it fluctuates.
It will be perfect for a long time, and then just enough to barely keep seeing a pixelated picture.
Several times it would just completely vanish although the other signal AND quality levels for the other channels on this sat did not budge.
I haven't been in this for too long - but this is a first where you can actually watch the quality signal start going down as if someone is slowly moving your dish away from it - and then it just pops right back when the other stations don't change.
-phil
