KUIL Fox Beaumont
$905.00
boomer_106
886
6
Can anyone confirm if this channel is still up? It was at AMC 4 101* W The freq was 11708 (V) 2170 SR. I keep saying " was" because I can't seem to tune it in. Even blind scan isn't pulling it up. Also "thelist" isn't showing this channel. :confused:
yes its still there...11706 V 2170
and yes the audio is WAY TOO LOUD!!
Iceberg most places list the freq at 11708. I just changed mine to 11706 and searched and it didn't find anything.
I guess my rec. doesn't like this channel. I've found it a couple of times but, usually no luck. I am getting ETN, Suroyo, CGN,TRWAM. Channels like veitnam plenata and a couple others show signal quality but, come up with no audio or video. Strangely enough earlier I was getting 3 abn but, now I'm not. You list that as strong so it's strange I'm not getting that but, I am getting the channels listed
LNB's are all different so I've seen it between 11705 & 11708
Are you sure you're aimed at AMC4?
KUIL is always a little buggy for me. I went out and pushed up on the dish a hair and it popped right in. Loudly :)
Yeah, as I said I'm getting those other channels. Fox is trying to come in now. I just don't have enough quality signal for whatever reason. It starts to come in the pixelates and freezes. I guess that's progress. Before I couldn't even tell if it was up
After reading this discussion, I went and found this channel because I had not heard of it and it had not come up on a blind scan.
When I entered in the transponder info - it came in at 50% S and Q. (which is good/decent on this viewsat)
But as I watch it - it fluctuates.
It will be perfect for a long time, and then just enough to barely keep seeing a pixelated picture.
Several times it would just completely vanish although the other signal AND quality levels for the other channels on this sat did not budge.
I haven't been in this for too long - but this is a first where you can actually watch the quality signal start going down as if someone is slowly moving your dish away from it - and then it just pops right back when the other stations don't change.
-phil
-phil
It must be really flaky. I'm thinking Iceberg built a 20 ft dish so he gets it perfectly;)
I don't watch it much, so I took a look, sparked from you'alls interest. And I found it's not as strong as it used to be, getting about a 66% on a 1.2m dish with a Pansat 3500s. It used to burst the meter? And I also notice the PID's have changed, from what I had.
Al
12-foot Paraclipse
AmericanLife TV Network
