DirecTV 10 Signal Reading Thread(Transponders are Hot!)
Hi, I live in Eagle Mountain, Utah. On 103 b I have nothing on the first two transponders but all others assigned show readings in the mid to high eighties.
I live in South Florida. On 103(b) i get nothing on the first two, then i get high 90's until #17
The lowest I have is 70, the highest is 80. Should I look into re-aligning my dish????
I remember one installer telling me 75 would be the minimum he would like to see.
get all 0's in South Carolina, hr20, with slimline 5 lnb set up... signal on on all the rest of the sats are @90's.... guess i'll have to wait to it's fully implented???
First 3 on 103b are 0s. All others are from the high 70s to mid 90s. Our time has almost come after 7 years of waiting for a real lineup of HD. Los Angeles CA
Omaha, NE
Light Overcast skys
01 - 08 | 0| 0| 0|93|76|88|87|86
09 - 16 |91|90|91|91|92|94|NA|NA
17 - 24 |94|NA|NA|NA|NA|96|NA|NA
25 - 32 (All NA)
103(b) readings from Orlando:
1-8 0 0 0 98 97 97 96 95 95
9-16 97 95 95 94 97 95
17-24 100 n/a n/a n/a n/a 100
25-32 n/a all across
n/a on everything else
Pretty high numbers from FL.
Same here in Wisconsin, all high 90's except for 1-3 @ 0.
I think I should just keep my HR20 unplugged as it will probably start to overheat the dish with all these extra satellite signals coming in! :D
Maybe they will keep the dish warm so you don't need to worry about losing signal this winter from the snow !!!
Jimbo
Pacific coast, H20(0F14), self made 1m (39") dish. Didn't final tweak, so the numbers are mediocre.
EDIT. Added same SS screen after got FW 0x2044 - little magic and number gone up without touching the dish !
You're using a way, way, out of date firmware. The signal strength will report about 20 points higher once you get upgraded.
9300 Now A&E
Still searching...
