771 Searching for Signal - Issue
LuRcH1080i
78
Manteca,CA
Ok,
I know there have been a alot of these threads. Sorry, I am just trying to find an answer myself.
Well I upgraded 6 months ago, received the HR20-700 worked great, around a week ago was recieving the signals to confirm ready for NEW HD Channels. I have the BBC on both (correctly installed). When NEW channels were released I only was getting (11) of the NEW (21) Channels. Now on the 11 I get the "Searching for Sat....771" error. At first I remember that the installer left behind a Multi-Switch. So I went and got that out of the garage, I noticed it was the Zenwell WB68, I knew from the requirements that it needed to be installed. Now this was after the Channels were release so I suspected that was the problem.
Soooo, I installed the Zenwell, still no fix. Tried Reboots, swapped BBCs (just the two I have on) with each other. No difference. When I do a Sat Signal test on 103b
I get 85s on just the even numbers NOT the odd numbers, wether it is Tuner 1 or 2.
I run through the System Test procedure and I get Tuner1 Ok, aquired 98% and Tuner2 OK,aquired 97%.
Now when I go through the Dish Setup, Dish Type: 5lnb, ....to the end I get these readings when done confirming:
Tuner1 OK
Tuner2 OK
Sat 101 OK
Sat110 OK
Sat119 Failed
Sat99b Failed
Sat103a OK
Sat103b Failed
And error summary says: -Your dish type is set to 5 LNB Multi-Sat, but the recorder detected three satallites.
Thats it, if anyone can give me any suggetions...thanks in advanced. And the only thing that I havent checked is the physical connections on the roof yet.
Get the installer back out out to your house. sounds like your dish isn't aligned properly you should be getting signal on 119 and 103b
Ok,
Tuner1 OK
Tuner2 OK
Sat 101 OK
Sat110 OK
Sat119 Failed
Sat99b Failed
Sat103a OK
Sat103b Failed
Did you see my post in the "If you are having trouble..." section of the DirecTV forum. I too was unable to get the odd channels only the even. Once I disconnected two lines from the multi-switch and connected them directly I got perfect signals readings on all sats & transponders.
Well I guess I could give that a try. As of now I only have 3 boxes including the HR20 in the house, however I plan to add one other D10 so I will eventually need to use the Multi-Switch right? Does it matter what cables I use to go directly to the HR20?
Direct TV Audio Dropouts and Random Reboots
H20 Tips and Tricks?
