211 recording to pocketdish
carefreepastor
5
I know I saw the answer to this someplace. Of course, I can't find it now. Search revealed no answer. I just bought a pocketdish 700. How do I record using the 211 event scheduler to the pocketdish. I know that it must be via analog inputs. I remember that the last update enabled something with the vcr item in the menu.
If I understand this post, over on DBStalk, then your handy dandy PocketDish turns your 211 into a SD PVR recorder via the USB port. Don't know what would happen if you tried to record HD to it...
Ah, there it is! I knew I read it someplace. Thank-you. I entirely spaced on the USB part though. I thought that I had to set the 211 up to record to the pocketdish as if it were a vcr.
Please let us know how it works. In this one way (recording to external disk), it's better than the EHD option for the 622/722!
You can setup using the pocket dish and using the VCR setup menu, choose the ERD Setup Screen that will display a message Disable or Enable recording to an external device. :)
NHL and NBA for free?
