I live in a fringe area and the outdoor antenna I use is designed to be amplified (powered) from the input into the receiver, so wondering if the HR 20's OTA input(s) are powered?
Noone at Direct seems to be able to tell me.
I would be able to say the HR20 has built in amplifier, and doesn't need an additional amplifier, this will cause a conflict and worsen OTA signal quality.
No, the HR20 OTA tuners are designed the same way in general as all the others and may need a preamp at the antenna to overcome signal losses just the same way any other OTA tuner might require one. Depends on the signal strength of the stations, cable losses etc. The OPs antenna probably has a built-in preamp and simply won't work without it. Before the new 103(b) satellite started transmitting in the b-band, you could connect one of the cables going to the satellite dish so it supplied power to the antenna pre-amp, and also diplexed the OTA signal on the same cable back to the HR20 OTA. With the new signal, you can't use diplexing, you need a separate cable to the OTA antenna, so you lose the power to the built-in preamp, and therefore you need to use a power injector on the OTA antenna cable to get power to the antenna preamp.
If diplexing like you say doesn't work, why bother, and yes one connection to the antenna in (OTA) the HR20 works well without amplification, on both tuners, since you have only one connector for both.
I guess that it can be trial an error, if you don't trust what I say, then do what you want.
I am completely confused by what you are saying. The OP has an antenna that has a built-in preamp. With DirecTV, the usual way to use such an antenna has historically been with diplexing, where power to the preamp is drawn from a satellite cable connected through the OTA antenna to the dish, and the OTA signal goes back down the same cable. But you can't use diplexing any more because the OTA signals and the b-band signals from 103(b) are in the same frequency band, so the only way to use the antenna is to have a separate cable from the HR20 (yes, a single connector drives both tuners) to the OTA antenna.
But this also means there is no source of power for the OTA antenna (since the OTA connector on the HR20 is not powered), and the antenna won't work without power, so you have to provide the power by using a power injector on the cable to the OTA antenna. None of this has anything to do with whether or not the HR20 OTA is amplified (which by the standard definition of that term., it isn't). With the separate OTA cable and the power injector, the antenna and the HR20 will work exactly the same as it would have done with diplexing in the past (actually slightly better, because you don't have the diplexer losses)..
If your HR20's are failing, your in trouble, since they are being reported as discontinued by many sponsors and DirecTV. So you are forced to get HR21 without OTA. Eventually it will have an external alternative at your expense, added expense, which sucks, but it is a wait and see situation.
Good luck.
Now I am even more confused. Who said anything about HR20s failing, or the HR21 - that has nothing to do with this post. All we are talking about here is how someone can get power to his OTA antenna when it is connected to the HR20.....
At this point it time, your statement is false. The HR20-100 continues to be manufactured and there are likely many OTA able machines being refurbished and returned to service.If your HR20's are failing, your in trouble, since they are being reported as discontinued by many sponsors and DirecTV.
Bookwalk for an amplified batwing antenna you need a standalone power supply and a RG6 cable from the HR20 to the TV antenna. Go to Welcome to Winegard, Makers of Television Receptions Products, UHF/VHF TV, Home Satellite, Mobile Satellite/Antenna, Medical Telemetry and search for PS-9370. You can probably go to Solid Signal | DISH Network, Off-Air HDTV, Dish HD and Digtial Home Advantage, DISH1000 & DISH500 HDTV satellite multiswitches and home entertainment supplies & accessories to buy one. Forget the gibberish that JTN is posting he dosen't seem to have any idea what he is talking about.
That is not correct. It has been proven time and again that diplexing OTA on to a 5LNB dish cable works just fine, as long as the BBC is input after the multiswitch and before the diplexer. Then, diplex it out again at the HR20, one to sat and the other to OTA. (There is no reason the BBC has to be at the HR20 end.).................But you can't use diplexing any more because the OTA signals and the b-band signals from 103(b) are in the same frequency band, so the only way to use the antenna is to have a separate cable from the HR20 (yes, a single connector drives both tuners) to the OTA antenna. ..
There's been a lot of threads on this at DBSTalk. It's working at my place right now.
Agreed. :upI have mine working this way too, but you are missing a very important point. Where the sat cable is passed through the antenna, in order to give power to a preamp, the first diplexer is actually at the antenna, e.g on the roof. Since the bbc is not designed for outdoor use, putting the bbc on the dish side of the diplexer is not a valid solution.
(I know some people have put the bbc in outdoor enclosures but I would not recommend this solution to anyone).
