HR20-700 {CE:10:07} - 0x1E Announcment
Systems in this CE / Version
HR20-700 {CE:10:07} - 0x1E?
Software Download Window:
Friday; December 21, 2007 11PM - 2:30AM ET
Saturday; December 22, 2007 11PM - 2:30AM ET
MUST READ AND AGREE TO: - The CE Rules, Faq and Tips Thread... Here
Please join "us" in the CHAT room, about 15 minutes before the window opens... and till... well to the last person turns off the lights...
http://chat.dbstalk.com
Important notes regarding this version
This has been a very aggressive CE cycle. And with that, there was a sgnificatnly increased level of risk involved with previous versions. While the risk has been greatly minimized at this point, there still is a small risk.
There is LITTLE risk that your box will become a brick... and if you are having too many issues, role back to the national release version.
So please you must absolutely understand these risks, before forcing this download
The Contents of the Release: (Differences based of Last National Release)
  • Items from CE:10:01
  • Items from CE:10:02
  • Items from CE:10:03
  • Items from CE:10:04
  • Items from CE:10:05
  • Items from CE:10:06
  • Items from CE:10:07
Improved
  • 01 - Recording dependability
  • 02 - DoD PgUp/PgDown consistent now
  • 02 - Many MediaShare fixes
  • 03 - Fix for certain video related issues
  • 03 - Audio from video files
  • 03 - VOD resume playback of partially downloaded program
  • 03 - In the DoD Homepage, RED/GREEN will not lock up the STB when viewer is using a custom channel list that doesn't include the DoD channels.
  • 03 - Remote Recording reliability
  • 03 - Remote Recording properly handle cases where recording was already set
  • 03 - 30 sec slip when at end of buffer
  • 03 - Incorrect resolution display
  • 04 - Misc fixes for reported issues
  • 05 - Stability Fixes and Stability after Software Download
  • 05 - Green key cycles audio tracks
  • 05 - Faster signal meter
  • 05 - Fixed frozen video frame
  • 05 - Fixed CC characters from dropping
  • 05 - Fixed review buffer from exceeding 90 minutes
  • 05 - Support play from playlist while getting 771 message on ATSC channel
  • 06 - Misc UI Corrections
  • 06 - UI Menus close when selection is made (like clicking on CC ON)
  • 06 - Green button changes audio directly, and shows banner display
  • 06 - Improved search stability
  • 06 - Interactive app performance improved
  • 07 - Stability improvements
Updated
  • 01 - Items in the DoD download queue, will remain after a system reboot
  • 02 - MP3s supported 06 - Native MP3 support removed, will return in a later CE
  • 02 - HDTV is a searchable term (=High Def)
  • 03 - Term "VOD" can be used in keyword search
  • 03 - Red Button Delete disabled on Mark and Delete screen
  • 04 - Updates to the UI (more about this after the CE rolls out)
  • 04 - Mediashare ThumbNails improvements
  • 05 - Added Winter welcome screen
  • 05 - Fix resolution indicator in native mode
  • 06 - Reliability when IP address has changed
New feature(s)
  • 01 - Triple Tap Lookup for DoD: When on a DoD page, you can use the # keys on your remote to enter letters in "cellphone/SMS" style. AKA: Hit #2 Three times to get a C
  • 01 - Adult Channel Hiding: This is an update parental control that is currently on the R15. When you enable this, it completely REMOVES the adult rated channels from the listings, almost as if they don't exist.
  • 01 - SLB Updates: Phase I - The live buffer should no longer EVER flush out for any other reason then changing the channel on the live buffer. Note the Phase I, they are planning more updates for the SLB
  • 01 - IP Callback: The ethernet/internet connection, will now be used for communication back to DirecTV for: PPV purchases, GameLounge, and other items that the phone line was required for
  • 01 - Mediashare Video Support: Phase I - You can now access video files from your PC. Note the Phase I, they are still working on additional codec's and full codec support; There is the possibility you will get video but no audio. This is a known issue, and will be worked on for future builds
  • 01 - 30 Second Skip: You will now have the choice between 30s SKIP or SLIP. To enable: Keyword Search 30SKIP or 30SLIP
  • 02 - Boolean Keyword searching, 3 new keywords AALL, AANY, NNOT
  • 02 - 720p/1080i reminder pop up if TV supports but is in 480i/p and tune to HD channel
  • 04 - Hitting Enter on a Full Screen, will display last 6 digits of receiver ID
  • 04 - Guide: Channel Color shadding to represent subscribed vs unsubscribed channels
  • 04 - Shortcut for Closed Caption On/Off
  • 05 - Triple-tap 'enter' key moves to next letter
  • 05 - SLB Updates: Phase II - Playback resumes from paused position on tuned channel
  • 05 - Hitting SELECT on a Full Screen, will display receiver ID
  • 05 - Hitting DASH on a Full Screen, will display LAST 6 Digits of receiver ID
  • 06 - Edit Series Link options when no episodes are found
  • 06 - SWM Version displayed
Notes
  • Absolutely 100% make sure you understand the risks of this download.
  • 04 - This version still carries a high risk level
  • 02 - Boolean keyword search examples: See this post
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
0x01E4 coming tomorrow? Maybe Friday and Saturday. Doug Brotts site was accurate last weekend on 0x01E2 (Which was an internal test marked in Red on his site). I would post his site but it is blocked by SatelliteGuys.US.
Why don't you post it. I have never seen a link be blocked here yet. From the other thread you might be the one with the problems with links not the site.
What's funny is if JTN is using this as his alternate source for CE announcments. Doug is a moderator at dbstalk!:D
Doug has no issues with me personally. He doesn't agree completely with all the others at DBSTalk. That is why he has his own sites. And he doesn't have any bias.
DBStalk has a post exspicitly saying there will be no upates this weekend.
We will see who is right.
0x1E? tonight or tomorrow for HR20?
Hr20-700 Ce 1-4-08
