Help with setup
neoflex
2
Installed a new satellite slimline dish with the 5-LNB and putting in the new HR 21 700 HD DVR.
I have great signal strength on the 119 (90%), but nothing on the 110 (etc.103). SO not sure if there is a setup error, or do I need to continue to play around wtiht the dish pointing.
THanks
Ok...still figuring this out. Did tweak the dish, and now I am getting the 110 and 119, but nothing on the 101 for satellite strength.
Any suggestions....as wondering if this is still a dish pointing issue.?
You should be using the 101 to peak the dish in the beginning and go from there.
If you have the 110 and 119, it's probably a tilt issue.
I always start with the 101.
Jimbo
I'm guessing you are pointing at 110 and not 101.
Jimbo
I would also triple check that the mast is plumb, and your presets are correct. I do agree that if the mast is plumb, it is probably a tilt issue.
Good point,
I forgot to mention that, the mast needs to be plumb before anything else is done or all your other adjustments will be off.
Jimbo
