DishNetwork Uplink Activity Report - 3/5/2008 12:40pm - 48 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 03/08/2008 - 39 changes
Uplink Comparison Range: 03/05/2008 12:15P - 03/05/2008 01:05P -
716 - STAR+ [MPEG2 SD] added to Anik F3 118.7W TP 17 ConUS beam (Not Available)
716 - STAR+ [MPEG2 SD] added to EchoStar3 61.5W TP 08 ConUS beam (Not Available)
718 - STAR1 [MPEG2 SD] added to Anik F3 118.7W TP 17 ConUS beam (Not Available)
718 - STAR1 [MPEG2 SD] added to EchoStar3 61.5W TP 14 ConUS beam (Not Available)
5160(9) - WFTV [MPEG4 HD] added to Echostar12 61.5 TP 03 Spotbeam 2? (Not Available)
5161(6) - WKMG [MPEG4 HD] added to Echostar12 61.5 TP 03 Spotbeam 2? (Not Available)
5162(2) - WESH [MPEG4 HD] added to Echostar12 61.5 TP 03 Spotbeam 2? (Not Available)
5163(35) - WOFL [MPEG4 HD] added to Echostar12 61.5 TP 03 Spotbeam 2? (Not Available)
5170(26) - WZVN [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
5171(11) - WINK [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
5172(20) - WBBH [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
5173(36) - WFTX [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
5180(25) - WPBF [MPEG4 HD] added to Echostar12 61.5 TP 01 Spotbeam 2? (Not Available)
5181(12) - WPEC [MPEG4 HD] added to Echostar12 61.5 TP 01 Spotbeam 2? (Not Available)
5182(5) - WPTV [MPEG4 HD] added to Echostar12 61.5 TP 01 Spotbeam 2? (Not Available)
5183(29) - WFLX [MPEG4 HD] added to Echostar12 61.5 TP 01 Spotbeam 2? (Not Available)
5714 - ZEETV EchoStar9 121W TP 29 ConUS beam MPEG2 SD changed to ICBLE - EchoStar9 121W TP 13 ConUS beam MPEG2 SD
5714 - ICBLE [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5975 - XWPRI [MPEG2 SD] added to EchoStar3 61.5W TP 16 ConUS beam (Not Available)
5982 - XWCHS [MPEG2 SD] added to AMC-15 105W TP 18 ConUS beam (Available)
5983 - XWSAZ [MPEG2 SD] added to AMC-15 105W TP 18 ConUS beam (Available)
6353(6) - WPVI [MPEG4 HD] added to Echostar12 61.5 TP 11 Spotbeam 5? (Not Available)
6354(3) - KYW [MPEG4 HD] added to Echostar12 61.5 TP 11 Spotbeam 5? (Not Available)
6355(10) - WCAU [MPEG4 HD] added to Echostar12 61.5 TP 11 Spotbeam 5? (Not Available)
6356(29) - WTXF [MPEG4 HD] added to Echostar12 61.5 TP 11 Spotbeam 5? (Not Available)
6359(7) - WJLA [MPEG4 HD] added to Echostar12 61.5 TP 05 Spotbeam 5? (Not Available)
6360(9) - WUSA [MPEG4 HD] added to Echostar12 61.5 TP 05 Spotbeam 5? (Not Available)
6361(4) - WRC [MPEG4 HD] added to Echostar12 61.5 TP 05 Spotbeam 5? (Not Available)
6362(5) - WTTG [MPEG4 HD] added to Echostar12 61.5 TP 05 Spotbeam 5? (Not Available)
6465(11) - WTVD [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
6466(5) - WRAL [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
6467(17) - WNCN [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
6468(50) - WRAZ [MPEG4 HD] added to Echostar12 61.5 TP 15 Spotbeam 2? (Not Available)
7315 - WCHS moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)
7317 - WSAZ moved from AMC-15 105W TP 18 ConUS beam to AMC-15 105W TP 02 ConUS beam (A)
9955 - TST16 (NA) removed from EchoStar1 148W TP 23 ConUS beam
Transponder Changes:
Echostar12 61.5 TP 15 Spotbeam 2? changed modulation scheme from QPSK to 8PSK
Echostar12 61.5 TP 15 Spotbeam 2? changed symbol rate from 20000 MSPS to 21500 MSPS
Echostar12 61.5 TP 15 Spotbeam 2? changed FEC from 5/6 to 2/3
Channels in the system: 4746
(A) = Available to subscribers
(NA) = Not Available
Looks like the spotbeaming of 61.5 has begun. I'll have to check my signal levels on the Washington HD locals when I get home.
Wow! We have channel names! Obviously this report will take some hand editing due to the not avail/avail anamoly. I am mobile right now and can not edit it well.
Can someone breakdown the markets here? Thanks.
HD Locals added to 61.5 Spotbeam 2 (somebody up there likes Florida)
Orlando, FL
Naples/Ft. Myers, FL
West Palm Beach, FL
HD Locals on 61.5 moved from CONUS to Spotbeam 5
Philadelphia, PA
Washington, DC
HD Locals moved from 118k to 61.5 Spotbeam 2
Raleigh/Durham, NC
*note* is Spotbeam 2 so big that it reaches Raleigh and Florida?
Looks like Florida got it.
The 5160's are Orlando area stations
The 5170's are Ft. Myer's area stations
The 5180's are West Palm Beach area stations
?6356(29) - WTXF Echostar12 61.5W TP 11 ConUS beam MPEG4 HD changed to (MAP:{29~}) WTXF - Echostar12 61.5 TP 11 Spotbeam 5? MPEG4 HD
6356(29) - WTXF [MPEG4 HD] added to Echostar12 61.5W TP 11 ConUS beam (Available)
Seems like a contradiction.
The Florida Locals are new.
Raleigh kinda sorta would be, as it was on 118 and never turned on before. We'll have to see if these are turned on.
All of the Raleigh locals were turned on in 07. What is interesting about this is that dish will have to add an additional dish for all hd subscribers for the 61.5 satellite.
ah, ok.
Hopefully the Raleigh people were given 61.5 instead of 129 when they were set up with a 1000+. Otherwise some people have lost their locals.
But since the report shows it as Not Available on both, probably some angry people either way.
Read back on my post...the older Raleigh locals should still be available.
Also, the TID assignments are guesses right now. Please note the question mark after the Spotbeam number.
Check TheList if you have any questions of the lay out.
I'm a little confused are these newly added HD markets or just newly added to the 61.5
6353(6) - WPVI [MPEG4 HD] added to Echostar12 61.5W TP 11 ConUS beam (Available)
6354(3) - KYW [MPEG4 HD] added to Echostar12 61.5 TP 11 Spotbeam 5? (Available)
6355(10) - WCAU [MPEG4 HD] added to Echostar12 61.5W TP 11 ConUS beam (Available)
6359(7) - WJLA [MPEG4 HD] added to Echostar12 61.5W TP 05 ConUS beam (Available)
6360(9) - WUSA [MPEG4 HD] added to Echostar12 61.5 TP 05 Spotbeam 5? (Available)
6361(4) - WRC [MPEG4 HD] added to Echostar12 61.5 TP 05 Spotbeam 5? (Available)
6362(5) - WTTG [MPEG4 HD] added to Echostar12 61.5W TP 05 ConUS beam (Available)
If they are newly added markets then good deal, at least we know there's some life at Dish....if they're just 'moved' to 61.5 then its another ho hum report
D
DishNetwork Uplink Activity Report - 3/5/2008 4:20pm - 42 changes
D
DishNetwork Uplink Activity Report - 3/5/2008 8:08pm - 43 changes
