Wow, I agree with Jeff, I guess the world is about to end...Use the wrench on other connections - never use a wrench on a tv or receiver!!!
He is correct, do not use the wrench on the tv or STB, you could damage the unit if you twist too hard
I know, you really let me down here jeff.I'm sorry I couldn't be more controversial over this one.
Maybe next time!![]()
Pixelation is not the hallmark of a correctly installed HD system. You either have too low of signal or you have poor cable connections.
Your connections should be examined closely, looking for any foil or strands of the braid that are near or touching the center conductor. Your system should be grounded correctly, and checked for loose connections. Barrel connectors (F-81) should be 3.0 Ghz and a failing barrel connector can cause pixelation as well.
If there is still pixellation, you may need a better installer or a separate dish for 129.
Atta boy Jeff! I knew you wouldnt let me down!All is not lost, msmith 198025! My first post suggests low signal OR poor connections. Certainly I would suggest a re-peak if the heat issue turns out not to be the problem.
To reduce pixelation you must either address the noise and reduce the noise floor or increase signal. Is there anything else that could be done, short of replacing failing LNB or receiver?
