I received my system from SatelliteAV and went to point the dish today.  The mounting post is perfectly level, so I installed the motor & dish as close to TS as possible.
When I checked it, signal was at 80 quality at 30. I adjusted and ended up with 82 signal and 72 quality on 97 (my zip is 78572). I then tracked it over to 123 and had 80 signal and 5 quality. Figured no biggie, atleast if found it. Then I tracked over to 89 and got signal there. Here is the fun-
I went bacck to 97 and nothing. Nothing anywhere. Everything is tight. After a little investigating, I found the shaft of the motor has play to it. I could touch the dish, and it would get signal. I set it, and after moving it, it looses signal again. It's pretty sloppy.
I have it at 123 right now, but am only getting 18 channels. How easy would it be to make it stationary/disregard the motor (there is no dish skew)? I am still waiting for a response from SatelliteAV.
