What signals can you "see" at 61.5?
ViP622 L449
Zip: 78681 (Round Rock, TX/Austin Suburb)
01 62 NNA
02 57
03 NL
04 NL
05 70
06 62 NNA
07 69 NNA
08 62
09 87
10 62
11 70
12 76
13 73
14 74
15 37
16 62
17 39
18 64
19 48
20 51
21 43
22 49
23 57
24 55
25 66
26 NL
27 68
28 NL
29 66
30 41
31 70
32 60
I see why I can get TP 9 clearly from that beam and not the others.
The NNA's are probably leaks from the switch.
Do some of the odds show as Spotbeam on the signal screen?
Nope, I'm *NOT* seeing it change to Spotbeam on anything on 61.5 (I proved that it would by looking at 119 TP7 which is where the LIL SD stuff *IS* on a Spot).
TP05 still shows as TP.
01 - 77 NNA
03 - 0 NNA
05 - 0 NNA
07 - 80 NNA
09 - 49 Locked 61.5
11 - 0 NNA
13 - 73 NNA
15 - 73 Locked 61.5
Still some NNA, but now both 9 & 15 are showing 61.5.
Check your TP numbers below 20... mainly the odds, folks. More beams are coming online tonight.
I moved the 90cm over to 61.5 and I can lock 3 spotbeamed TP's. 2 are really low and I can't not get any info from them. TP 9 has the Beaumont HD locals on them though. 3 out of 4 are there, KBTV is only around 2 megabits. Barely sneaking this TP by on the signal meter. I'm really surprised I can get this beam when I'm on the western portion of the beam for Jackson, MS/New Orleans, LA area. Guess that proves the Jackson, MS site isn't online yet.
Can someone in Southeast TX check 61.5 transponder 9?
Say Digiblur I just checked my signal on transponder 9 on the 61.5 sat and I am getting an 89 strength on this one transponder . THis is with the new signal strength readings, so WOW! WE shouldn't have any trouble for Beaumont hd locals in this area; Zipcode 77627 Nederland,Tx.
You should be able to see the other transponders on the same spot beam at 5, 11, and 13. They should be a little lower in strength. That #9 is hot! I can see it all the way in South Central LA.
On 5 , I am getting 75 strength & on 11, I am getting 73 strength & on 13, I am getting a 75 strength.
28 Mar 08 - 10:30 AM CST
O'Fallon, IL 62269
61.5 - Dish 500
VIP722 - L4.49
NL = Not Locked
01 - NL Name Not Acquired
02 - 61
03 - NL Name Not Acquired
04 - NL Name Not Acquired
05 - NL Name Not Acquired
06 - 72 Name Not Acquired
07 - NL Name Not Acquired
08 - 71
09 - NL Name Not Acquired
10 - 68
11 - NL Name Not Acquired
12 - 84
13 - NL Name Not Acquired
14 - 77
15 - 47 Name Not Acquired
16 - 70
17 - 48
18 - 66
19 - 55
20 - 53
21 - 58
22 - 51
23 - 63
24 - 62
25 - 70
26 - NL Name Not Acquired
27 - 73
28 - NL Name Not Acquired
29 - 67
30 - 43
31 - 72
32 - 62
Coconut Creek, FL 33073
61.5 - Dish 300 DP34 switch
VIP722 - L4.49
NL = Not Locked
01 - 73
02 - 62
06 - NL Name Not Acquired
07 - 78
08 - 70
10 - 71
12 - 82
13 - 66 Locked Name Not Acquired?
14 - 80
15 - 80
16 - 67
17 - 46
18 - 71
19 - 52
20 - 52
21 - 48
22 - 55
23 - 59
24 - 59
25 - 73
27 - 70
29 - 70
30 - 46
31 - 71
32 - 63
My HD Locals (Miami dma) are on 110° Tansponder 12 spotbeam. What tansponder on 61.5° are West Palm Beach locals.
Anyone get better than low 30's signal on 61.5
I lost two HD channels in Puerto Rico
